+5
gotavan
9 posters
Accelorator pedal rebuild
wideload- Moderator 1st Class
- Number of posts : 1388
Mike
WIDELOAD
xjamesx- Number of posts : 378
Re: Accelorator pedal rebuild
i need those too so i am anxiously awaiting an answer...
Scott- Number of posts : 1651
My 68 just has a flat piece of plastic around the shaft, the plastic looks a lot like those two pieces. I just covered mine with grease and put it back together.
Well Scott, if I had a Chevy Van that needed accelerator shaft bushings, I think I would check this website and search for SLEEVE BEARINGS and see if any bronze or nylon bushings would work. ,,,,,,,,,,
http://www.mcmaster.com/#
Thanks for the info Don !!! Mine were so worn I didn't try to measure them. For now I just did what Scott did, cleaned everything up and lubricated it real good.
The closest one I found on McMaster was only .625 OD. That would probably still be better than the worn out ones that are there now.
Mike
WIDELOAD
gotavan- Number of posts : 242
I just replaced the nylon bushings with brass, took some old fittings and turned them on lathe.
GreyFoxMC- Number of posts : 56
Registration date : 2008-06-02
Gas Pedal Bushings (2 req) GM # 3710620
Still available as of last year at your local dealer (2008)
Thanks Don & GreyFox !!!!!!!!!!! With all this info the bushings shouldn't be any problem.
Mike
WIDELOAD
ViewMaster- Number of posts : 117
Great job!!! I felt sure that Don would have a fix but Greyfox knowing that they are used on Vettes makes you think that they will be around for awhile. Seriously if it weren't for the collection of vanners mind on the internet I would of had to give up on these obsolete old vans.
Vanish- Admin
- Number of posts : 5155
I Just Got One Question here !!!! This same Bushing is Good for 1st and second Gens ?????????
,,,Vanish,,,
MCMLXV
White lithium grease...
clearly I have a fetish for white lithium grease. However, I recommend it highly when lubing such an assembly that mixes metal with plastic or rubber bushings. WLG will not dissolve the polymers over time like regular grease will and it pretty good with shedding water. Just my 2 cents. Also, those shifter grommets are still available.
When I get back to my regular computer I will try to look them up.
Happy motoring, Mark
How much pedal do you have?
My pedal moves about an inch and a half before hitting the floor, but the Carb could open much more.
I can't push the linkage forward because it hits the Master Cylinder, so I've been thinking about trying to extend the linkage where it connects to the pedal shaft underneath, that would raise the pedal inside. The linkage has plenty of room to move back farther, but the pedal bottoms out on the floor.
How high is your pedal from the floor?
So the gas pedal is not pulling the throttle plate all the way open,,,,,,,how about step on the gas pedal and try move the linkage at the carb by hand and see if you can get more opening of the throttle plate. Also see if there are other holes in the linkage that will allow you to change the fulcrum point of the system.....
