    spring bushings and shackle bushings
    hywaychild
    hywaychild
    Number of posts : 389
    Registration date : 2008-05-27
    spring bushings and shackle bushings Empty spring bushings and shackle bushings
    Post by hywaychild Thu Feb 12, 2009 11:34 am
    just in case someone is still in need of a set of front spring bushings for a 1964 to 1966 chevy
    they are part # rb92 from general spring in olatha KS 18003993852 and i got the rear shackle bushings at rareparts.com BUT they were not quite right i had to use a steel spacer bushing to make them work
    [img]spring bushings and shackle bushings 64rebu21[/img]
    spring bushings and shackle bushings Empty Re: spring bushings and shackle bushings
    Post by donivan65 Thu Feb 12, 2009 1:37 pm
    How much are those metal cartridge ones???? And do they fit the spring and the bolt? What was the part number of the shackle bushings and how much did they cost??????
    hywaychild
    hywaychild
    Post by hywaychild Thu Feb 12, 2009 2:50 pm
    spring bushings and shackle bushings 64rebu32
    [img]spring bushings and shackle bushings 64rebu28[/img]
    theses are the shocks that i used , there off of a 96 toyota pick up . i had to use the shims out of the old shocks because toytoa used a 1/2 bolt and chevy used a 7/16 or a 3/8 bolt ? I just cut the shim out of the old shock they worked fine .
    [img]spring bushings and shackle bushings 64rebu29[/img]
    these are the shackle bushings they were close but not right so i cut a piece of pipe and used it for a shim now they both fit nice and tite . I got them from orilies auto parts part # cl608610 for 17.44 you might get them derect from rareparts.com thats were they got them . they might even have a better fit ?
    I could of sent them back but it just seemed easier to make them work .
    spring bushings and shackle bushings 64rebu33
    [img]spring bushings and shackle bushings 64rebu30[/img]
    and theses were the front spring bushings part # RB92 the price on them was about 55.00 with shipping
    spring bushings and shackle bushings 64rebu34
    Number of posts : 7900
    Post by DanTheVanMan Thu Feb 12, 2009 4:08 pm
    Got it. Thanks Jay. Not a bad price either....
    spring bushings and shackle bushings Qr_cod10
    VanGo66
    Number of posts : 65
    Registration date : 2010-09-08
    Post by VanGo66 Mon Sep 27, 2010 9:02 pm
    Rock auto also has a listing for acdelco bushings as well as Raybestos bushings. Priced way better than Rareparts.
    http://www.rockauto.com/catalog/raframecatalog.php?carcode=1322198&parttype=7488&a=FRc1322198k356378-1671857
    GreyFoxMC
    GreyFoxMC
    Number of posts : 56
    Registration date : 2008-06-02
    Post by GreyFoxMC Wed Sep 29, 2010 2:24 am
    The highlighted number is the original. 3848684 - HB698
    Closest to original is HB533
    Head is only 1/8th larger - ID & OD length are the same.
    www.truckcomponentsonline.com/RUBBER-_c_326.html+3848684+bushing&cd=3&hl=en&ct=clnk&gl=us" target="_blank" rel="nofollow">http://webcache.googleusercontent.com/search?q=cache:N85nLA9WDR0J:www.truckcomponentsonline.com/RUBBER-_c_326.html+3848684+bushing&cd=3&hl=en&ct=clnk&gl=us
    VanGo66
    Post by VanGo66 Wed Sep 29, 2010 5:43 am
    Now we just need to find a cheaper alternative for the front bushing on our rear springs.
    Post by donivan65 Wed Sep 29, 2010 9:25 am
    spring bushings and shackle bushings Spring10
    VanGo66
    Post by VanGo66 Wed Sep 29, 2010 10:44 pm
    info on the rear poly bushing?
    http://www.energysuspensionparts.com/proddetail.asp?prod=4.2126
    Are these the same as what you pictured.
    Post by donivan65 Wed Sep 29, 2010 11:20 pm
    These #2056 Neoprene bushings with a #6 sleeve replace those front cartridge type bushings on a 1st Gen,,,,,,,I don't know if that part number is the same,,,,,,,
    spring bushings and shackle bushings Spring11
    spring bushings and shackle bushings Treesp10
      Current date/time is Sat Apr 27, 2024 4:12 pm
