leaf spring bushings
redvango- Number of posts : 112
Registration date : 2015-06-27
Has anyone found leaf spring bushings in the last year for a first gen g10? Donavans post go'es back 2013 and those companys have faded a way! I'm going to call energy suspension! I thought i'd see if anyone has bought bushing lately?
Re: leaf spring bushings
leaf bushing
That right doni! the front is a cartridge that's 1-5/8 OD the shackles are 1-1/8 just rubber with a collar for the connecting plate's to pivot on! I called the places on your 2013 post no longer exist! There in a national spring in milwaukee but they would need the dimensions to make rubber one's ! Energy suspension can make Urethane given the dimensions! I was just hope that some one has had them made!?
savage and Russell like this post
savage likes this post
leaf bushing
Thanks Doni:) I got both the front leaf's off and by tape their both 1-5/8 left and right!? funny just had rubber bushing's no cartridge in the back of leaf? hopefully tomorrow I can get the back leaf's off? maybe those will have the cartridge in the shackle? Thank you as always (JOHN) aka Redvango
Shackles dont use cartridges just 4 half rubber bushings,,,,,and after over 50 years, you dont know what has been done to a vehicle,,,,,so you dont know what you got till you tear it apart,,,,,,you might have corvan, pick up or nova parts,,,,,Lets see some pictures of what you got,,,,,If you got those big metal cartridges in the springs, I wouldnt be pressing them out until I found some kind of replacement or you wont be driving that van,,,,there is always a chance that the van was ordered with heavy duty suspension too and tougher springs,,,,,if you just want to take a peak at the front bushing on the rear springs, you can put a jack between the spring and frame and remove the bolt and jack the spring down enough to see the bushing,,,,you could probably change the bushings without removing it from the rear end if they are bad.
gfleduc- Number of posts : 367
FYI for the front springs; forward eye, chevy use three different combinations of bushings. Therefore measure both sides before ordering.
1st combination - Both sides uses std bushings 1-1/8 OD (p/n 3834082).
2nd combination - LH side uses std bushing & RH uses HD bushing 1.625 OD.
3rd combination - Both sides uses HD bushings (p/n 3884082).
need 1-5/8 or 1.64
I found a couple of place's the make urathane parts and waiting to here back! Napa found rare parts had the cartridge's that fit so I order those and if the urethane come through I'll just sell them though the club!!
i just order a couple urethan universal bushing that are bigger and longer and a buddy said he would help me turn them down on his lathe !! fingers cross the cost $79 dollars!
So what part numbers from where,,,,,is the bolt sleeve correct,,,,,,keep putting up information, right or wrong, sooner or later people got to crawl under their van and check their spring bushings.
leaf bushing
the company is susenion.co part# 9.948 Flange type bushing OD 1.75 in.ID.875 in.Tub lenght 2.56 in. Black or red two pack $29.53 each! I let you if i can make them fit?! th e hot rod mechanic said i could use his milling machine to size them to specs! Wish me luck
leaf bushing
the gay said the sleeve will fit 5/8 od bolt or 1/2" course bolt
just an up date!The shackle energy bushings #4.2126 use a 9/16th bolt not 1/2 inch witch is no big deal drill the shackles a1/16" bigger hole and i found an for the front leaf's in stead of the energy 9.488G witch has a 5/8 bolt prothane #19-610 only needs 1/4" cut off and turn down form 1"-3/4 to the 1.61" and has a sleeve for a 9/16th bolt
Space Truckin- Number of posts : 1279
- Post n°19
Lots of good info, just no love for the 2nd gen...
- Post n°20
leaf bushing
My shackles only had rubber with 1/2" bolts not cartridges
- Post n°21
I would easily speculate a prior owner replaced the grommets and bolts for a working repair solution for them. As stated prior the bolts are Ø9/16". (P/N 3848685 per the parts book 3-5/8" long).
- Post n°22
The metal cartridges are only in the forward side of the springs, the rear ends of the springs have the shackles and only have 4 rubber bushings just slide into the frame and spring eye and the 2 carriage bolts hold the shackle together but you dont know what you got until you take it apart.
- Post n°23
- Post n°24
leaf bushing
sorry no sleeve's! I hope to get over to the van Friday I'll take pics
- Post n°25
leaf bushing
Skulptorchaz likes this post
