    Radio in a '64
    Radio in a '64 Empty Radio in a '64
    Post by Guest Fri Sep 04, 2009 9:50 am
    i'm wiring in an in-dash dvd player with fold out monitor to my 64'. problem is, i've no idea where to tap in for my constant or ignition wires. the van's dash is uncut, and i'm unfamiliar with the fuse box. any suggestions?
    Radio in a '64 Dash10
    primaldesigns
    primaldesigns
    Number of posts : 71
    Registration date : 2009-01-11
    Radio in a '64 Empty Fuse Panel
    Post by primaldesigns Fri Sep 04, 2009 11:45 am
    The fuse panel is mounted under the headlight switch. The panel contains the parking, rear and dome light fuse, radio, turn indicator and heater fuses. Hope this helps.
    Radio in a '64 Scan0010
    Number of posts : 655
    Radio in a '64 Empty Re: Radio in a '64
    Post by 61econoline Fri Sep 04, 2009 11:57 am
    I see you have one of the 4 speeds on the column thats cool
    Number of posts : 2067
    Post by sasktrini Fri Sep 04, 2009 12:04 pm
    Also, the back of the ignition switch, on the centre post, is hot at all times I believe... can't remember. Don't know if the fuse is hot in Run or all times... but one connection (probably ign sw) would be for memory.
    Post by Guest Fri Sep 04, 2009 12:19 pm
    thanks for the advice, and the diagram helps a lot also. alas the 4spd is long gone. only the linkage and knob remain. she's a 3spd now
      Current date/time is Tue May 07, 2024 12:01 pm
