    3 speed manual tranny to th 350?
    3 speed manual tranny to th 350? Empty 3 speed manual tranny to th 350?
    Post by Guest Sun Aug 30, 2009 11:04 pm
    Hey all,
    I will be pulling the 230 out of my van on weds and i was wondering how to swap in a th350 tranny with the mounts how they are on the manual tranny. there is no cross member just a stabalizer bar mounted to the side of it. any ideas? oh will be taking plenty of cool pics of my 66 during the process it will be cool!!!!
    Thanks
    Big Noer
    Number of posts : 2626
    3 speed manual tranny to th 350? Empty Re: 3 speed manual tranny to th 350?
    Post by savage Mon Aug 31, 2009 7:45 am
    You would have to find one of the Rare T 350 hangers (for a short shaft 350), Or you can make a crossmember for it. Good Luck with your new project.
    Number of posts : 1651
    Post by Scott Mon Aug 31, 2009 8:22 am
    You might want to read this thread,
    https://vintage-vans.forumotion.com/g-van-general-discussion-f4/auto-transmission-swap-t3530.htm?highlight=transmission+mount
    As far as hangers go, I pulled this from that thread,
    donivan65 wrote:The original Van transmissions hang from the floor crossmember ,,,,,,then they made a hanger that bolted onto the TH350 trans,,,,,,but the 700 and the 200 overdrive transmissions have the mount on the bottom so you need to build a hanger for it. Also,,,you will need a different driveshaft front yoke,,,,,PG has different number of splines than a 700r4,,,,,,,
    3 speed manual tranny to th 350? Polar_10
    3 speed manual tranny to th 350? Chevy_14
    Post by Scott Mon Aug 31, 2009 9:36 am
    Good reference guide pulled from: http://www.transmissionplanet.com
    3 speed manual tranny to th 350? Pictur20
    Post by Guest Tue Sep 01, 2009 12:12 am
    thanks for the info
    b noer
      Current date/time is Sun Apr 28, 2024 6:23 am
