    3 Speed Tranny Identification
    kawadawg
    kawadawg
    Number of posts : 24
    Registration date : 2012-06-01
    3 Speed Tranny Identification Empty 3 Speed Tranny Identification
    Post by kawadawg Fri Aug 17, 2012 9:10 pm
    I have a 1961 Econoline Pickup that I need to know what the factory transmision is. It is a 3 speed column shift and as far as I can tell it is the original. I need a seal for the rear output shaft.
    Number of posts : 2011
    3 Speed Tranny Identification Empty Re: 3 Speed Tranny Identification
    Post by Barnabas Wed Aug 29, 2012 8:12 pm
    1961-1962 used the light duty HEF-A transmission often referred to as the "crash box." The access cover was on the side.
    From 1963-1967 they used the heavy duty HEF 3.03 transmission. The access cover is on the top.
    A 1963-1964 trans is much better than the 1961-1962 and should bolt right up to your engine and frame.
    The 1961 transmission should have 1U3B or 1U3C marking on the side of the case, and as I said, it has the side cover.
    According to the Ford Truck Parts Catalog, on your 1961, the output shaft oil seal is A2TZ 7052-A (2.378: O.D., 1.5" I.D., 0.75" thick)
      Current date/time is Thu Mar 28, 2024 1:17 pm
