I am looking for suggestions on what sound / heat matting to use for my 1983 GMC Vandura.
Sound / heat floor mat
dlester56- Number of posts : 1
Registration date : 2023-11-21
dlester56 likes this post
AzDon- Number of posts : 742
Re: Sound / heat floor mat
Scroll down and you will find a section with "Between the Seats" forums and the last forum there is "Interiors"....
It has several threads regarding insulation...
gmytych and dlester56 like this post
- Number of posts : 8729
dyno mat for sound
wylee- Number of posts : 917
shag carpet works too lol
chrlsful- Number of posts : 184
"..."Between the Seats..."
which make, Don. They have 1 for each of the Big3
what ever you use fiberglass, foam, bubble wrap the walls need to breath to counter the condensation in the walls or ceiling don't ruhn your wall covering tight to the floor. or it will rust.
gmytych likes this post
i thought that was what paint was for (rust).
Yes those 'barriers' (continuous sheets) contribute, but some 'breath'.
There are compounds U can put on (like manufacturers) thik[n putty like, lizard skin, ceramic paint. I like a combo (yup w a y more wrk) of these AND the blockers (a metal 'blocker' again as in oem -alu or other sheet/panel on stilts) like the heat shield.
I refuse to have 'rugs' on certain vehicle floors so have hada avoid 'under pads' & similar solutions in certain vehicles (see avatar on right). W/the 'rug' there seems lots more solutions inc combos right there (sound'n heat). HTH
