    Sound insulation in the van
    Vantucky
    Vantucky
    Number of posts : 112
    Registration date : 2015-05-14
    Sound insulation in the van Empty Sound insulation in the van
    Post by Vantucky Sun Nov 15, 2015 8:12 am
    I just scored 30 square feet of fatmat to go under my flooring. Should I lay it in strips or just cover the whole floor. I'm going to do plywood on top of it with hardwood flooring on that. Any suggestions appreciated!
    Cheers,-Toby
    Number of posts : 1558
    Sound insulation in the van Empty Re: Sound insulation in the van
    Post by OutofSight Fri Nov 20, 2015 5:24 pm
    If it were me, I would lay it strips to make it stretch. That should still be plenty enough product to keep the noise Down.
    edfields
    edfields
    Number of posts : 71
    Registration date : 2015-04-19
    Post by edfields Thu Dec 10, 2015 10:20 am
    Vantucky wrote:I just scored 30 square feet of fatmat to go under my flooring.  Should I lay it in strips or just cover the whole floor. I'm going to do plywood on top of it with hardwood flooring on that.  Any suggestions appreciated!
    Cheers,-Toby
    Did you install in your van? How was the result? Did you use any other layering of materials?
    I'm looking to add insulation to my panel van and still collecting info to decide how I want to do it.
    Number of posts : 1279
    Post by Space Truckin Thu Dec 10, 2015 8:03 pm
    Just did lizard skin on my doghouse.....perfect! And cleans up with soap and water study
    Vantucky
    Vantucky
    Post by Vantucky Thu Dec 10, 2015 10:19 pm
    I did strips across the floor. Works surprisingly well.
    Next step is insulation/underpayment.
    I'm torn between 1/2" foam or doubled up 2mm underpayment. Any suggestions welcome!
    Than 1/4" plywood
    Topped with 1/2" engineered oak hardwood flooring.
    I want my van to be 4 seasons. So I plan on insulating the walls with r13 roll insulation too. Hope that helps. You can see some pictures here:
    https://www.facebook.com/benicia.smith.3/media_set?set=a.1161084710584841.1073741833.100000499700665&type=3
    Post by Guest Fri Dec 11, 2015 8:19 am
    Vantucky wrote:  Should I lay it in strips or just cover the whole floor.
    Yes!
      Current date/time is Thu May 02, 2024 12:29 am
