Has anyone ever put one piece windows in their A100? How big a job is this?
1 piece door glass
docmcg- Number of posts : 205
Registration date : 2014-09-08
1 piece door glass
69- Number of posts : 434
Re: 1 piece door glass
You mean to replace the two-piece windshield with a one-piece?
Why? That's some very special glas you'd need....
Not the windshield glass, the door glass. I’d like to get rid of the vent glass.
Maybe you can adapt a power window kit and get a piece of glass made to fit,,,,,you might need to adapt the front channel to match the new glass,,,,,,maybe you can still use the old regulator ,,,,,if no one has a pattern of the 1 piece glass, you can remove the vent assembly and make a cardboard pattern and see what a glass shop says, but you still need some kind of front channel for the new glass.
Gotcha
docmcg wrote:Not the windshield glass, the door glass. I’d like to get rid of the vent glass.
Ooops, I misread (i.e. NOT read) the topic properly. Soorry.
So what if someone wanted to put a 1 piece windshield in, is there much of a curve or how much work to adapt a flat piece of glass to fit?
donivan65 wrote:So what if someone wanted to put a 1 piece windshield in, is there much of a curve or how much work to adapt a flat piece of glass to fit?
I guess it'd need a quite sharp edge of like 5-8 degrees right in the middle. Not easy, if at all possible.
Considering the necessary effort, I'd drop that thought within a splitsecond.
