    Front Door Glass Run????
    ramian09
    ramian09
    Number of posts : 167
    Registration date : 2010-01-26
    Front Door Glass Run???? Empty Front Door Glass Run????
    Post by ramian09 Mon Jan 20, 2014 12:18 pm
    Does any one know if the door glass runs from macs antique auto fit? I just bought one and it looks like my old one, except that it is straight and my old one has a 90 degree angle in it?? How the heck do i install this thing?
    Number of posts : 292
    Front Door Glass Run???? Empty Re: Front Door Glass Run????
    Post by Vannin Ken Mon Jan 20, 2014 12:43 pm
    You might be able to find a general illustration online... You have to form around glass first then install
    ramian09
    ramian09
    Post by ramian09 Mon Jan 20, 2014 2:56 pm
    Really you think that I need to form it first!?!? It is the run that has the felt and metal trim on the front and it has the plastic clips/lugs that pop into the door on the back. Do you have any idea how one would go about forming it to the glass? Thanks
    ramian09
    ramian09
    Post by ramian09 Mon Jan 20, 2014 3:11 pm
    Front Door Glass Run???? Dsc_0014
    Front Door Glass Run???? Dsc_0015
    Front Door Glass Run???? Dsc_0016
    Post by Vannin Ken Mon Jan 20, 2014 5:21 pm
    I did a Ford truck years ago and that's how i did it. I had the glass out to fit then installed in the door at assy. Yours appears to be a little bigger bead which becomes difficult to bend. take your time
    ramian09
    ramian09
    Post by ramian09 Mon Jan 20, 2014 5:25 pm
    yep go slow
    Number of posts : 2198
    Post by EconoUSAparts Mon Jan 20, 2014 6:11 pm
    It should flex easily unless they sent you the one for the division bar which isn't flexible at all.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Tue Jan 21, 2014 11:26 am
    I have found that it is easier to form the channel around the glass with the glass removed, allowing the bead to slide as you bend it. Less chance of kinking it.
      Current date/time is Sat Apr 27, 2024 12:02 pm
