    Lots of fixes, but runs bad?
    LittleDoheny
    LittleDoheny
    Number of posts : 27
    Registration date : 2014-05-04
    Lots of fixes, but runs bad? Empty Lots of fixes, but runs bad?
    Post by LittleDoheny Sat Aug 19, 2023 12:25 pm
    Just a simple do it your selfer, some plugs, wires, rotor and cap.
    The thing is, they were all real bad, so I assumed when I replaced them, (looked terrible) that the van would run a lot better, but....it runs even worse????
    What are your thoughts, what do you think it could be then?
    Thank you.
    Doheny
    P.S. Plug-Gap ).35 ???? Correct?
    Lots of fixes, but runs bad? Empty Re: Lots of fixes, but runs bad?
    Post by donivan65 Sat Aug 19, 2023 10:26 pm
    Do you still have points, have you run a compression test,,,,,if you got a 6 cylinder, did you put the wires back in the 1,,5,,,3,,,6,,,2,,,4 firing order,,,, like how many miles on that engine,,,,where you located?
    Number of posts : 744
    Post by kiwimopar Sun Aug 20, 2023 3:36 pm
    Bad gas in the tank?
    Loose wiring around the engine?
    Fuel pump blocked?
    Carburettor needle valve stuck (if fitted) ?
    Choke manually stuck part way?
    There are a lot of things it could be.
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Sun Aug 20, 2023 5:39 pm
    Dis you replace points and condenser? Did you check points gap with a dwell meter? Check Timing with a light? Assure no vacuum leaks? Check vacuum advance operation and for diaphragm leaks? Choke operation? Fuel filter(s)? air filter? Timing chain lash?
    It would help if you would describe symptoms...
      Current date/time is Fri May 10, 2024 4:20 am
