    A108 Drag Link Ends
    Arnolt
    Arnolt
    Number of posts : 10
    Registration date : 2018-11-27
    A108 Drag Link Ends Empty A108 Drag Link Ends
    Post by Arnolt Wed Jun 14, 2023 12:08 pm
    Are the ball joints at the ends of the drag link on a 69 A108 replaceable? The parts manual calls out P/N 9424 798, 9/16 - 18 hex but I can only find places that will sell the link complete. Any guidance would be greatly appreciated.
    Number of posts : 405
    A108 Drag Link Ends Empty Re: A108 Drag Link Ends
    Post by Keith D Wed Jun 14, 2023 9:44 pm
    Arnolt wrote:Are the ball joints at the ends of the drag link on a 69 A108 replaceable? The parts manual calls out P/N 9424 798, 9/16 - 18 hex but I can only find places that will sell the link complete. Any guidance would be greatly appreciated.
    A drag links ends are not replaceable, you either have to get a whole drag link from Rare Parts or find an NOS one. Either way bend over and grab your ankles for the price will stick it to you big time.
    The good news is that the tie rod ends are replaceable and available.
    Arnolt
    Arnolt
    Post by Arnolt Thu Jun 15, 2023 8:07 am
    Thanks, I was afraid of that. Do you happen to know the part numbers for the tie rod ends?
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Thu Jun 15, 2023 11:52 am
    A REAL parts store can measure your ends and set you up with a pair of tie-rod ends with 5/8 or 11/16 male stems (one left thread and one right) and you buy a threaded tube in the appropriate length ( and jam nuts) from Speedway......
    Post this inquiry in "A-Van general discussion" and "Between the seats-A" and be patient and I'll bet somebody in the A van community will know the part numbers for those rod ends...
    Most American tie-rod and ball joint tapers are roughly 7 degrees, but you'll need to know the big end and small end hole diameters and the thickness the tie-rod bolts through (usually about 3/4")
    You may get lucky and find your ends here:
    https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
    but MOOG has hidden a lot of their classic offerings from this chart, so a REAL parts store (with stacks of paper catalogs and a guy that can use them) is your best bet...
    sweetvan likes this post
    Post by Keith D Thu Jun 15, 2023 2:33 pm
    Arnolt wrote:Thanks, I was afraid of that. Do you happen to know the part numbers for the tie rod ends?
    eBay has them, just search Dodge A100 tie rod end. The right one is cheap because they fit other vehicles also and are still being made by a few companies. The left ones are the problem they are harder to find and will run you some money.
    https://www.ebay.com/itm/185733839380?fits=Make%3ADodge&epid=579133386&hash=item2b3e997a14:g:-2MAAOSwQi9jvxP7&amdata=enc%3AAQAIAAAA8McRZBviZ2Pguf292ceCGXgd9jEELnurkcKUgd5HQBI41Wkm4e7B9aIMb6VlGZhIDJaTocTU9EqRH7hlcqtgD76n81XfNksuiTQAmQ%2BTaMUk%2BC%2B6n8WRuEmJKKKbaVPfTjke1TdA2yArvkgsi%2FPSbfLyQ3I2TfFsjgBNgVXEgaJgmLHXQNIRN14g59MMK6HrA19yRU50PVQEoeXYyjLcSJFwSOjSr%2FcEQcW1HkJIwRieVCDuObNthokhQG2y%2FR%2BMgs1xfEGhQqlx3AteNM6IhOSt3tNtp8bc%2FN5o9By%2BQ2xagPyd%2BIbctjmemI1oiq1CLw%3D%3D%7Ctkp%3ABk9SR77qlY-YYg
    AzDon
    AzDon
    Post by AzDon Thu Jun 15, 2023 10:09 pm
    Caution!..... on a chevy, the drag link ends are larger than the tie rod ends and that could be the case on dodge also......It would be easy enough to compare though....
    Arnolt
    Arnolt
    Post by Arnolt Sat Jun 17, 2023 7:22 am
    Thanks everyone for the info.
      Current date/time is Sat Apr 27, 2024 7:54 am
