As the title states, I’m looking for the hose that attaches to the fuel tank and then onto the steel fuel line. Is there a special hose for that and if so, is it available some where? I have all new 5/16” steel fuel line from the fuel pump back to the tank and was curious if there’s a specific hose to connect to the tank. Thanks, Steve.
Fuel tank hose
docmcg- Number of posts : 205
Registration date : 2014-09-08
Fuel tank hose
underdodge likes this post
Re: Fuel tank hose
You need 5/16"fuel line hose which just clamps on the sender and fuel line which they sell by the foot, not vacuum hose,,,,,,,unless you got something modified with fittings on the end.
- Number of posts : 8729
Re: Fuel tank hose
as Donnie stated,
But there is a ground strap that goes from the sender to the steel gas line so the sender is grounded
avail. on ebay or you can use 2 small hose clamp and a stranded copper wire for the ground
Re: Fuel tank hose
underdodge- Number of posts : 2
Registration date : 2015-09-08
fuel line
You can get the fuel line(hose) at NAPA, they sell it by the foot. Be sure and replace the clamps as well, it will save you trouble down the road. Good luck with it.
Re: Fuel tank hose
Thanks guys, got it handled. I was thinking there might have been a special formed or molded hose. I guess not.
