+7
Otto
demondog
chrlsful
lear0
13-ball
11 posters
    1961 Rust-O-Mod Pickup Build thread
    hammerinhank
    hammerinhank
    Number of posts : 14
    Registration date : 2018-12-11
    1961 Rust-O-Mod Pickup Build thread - Page 4 Empty Re: 1961 Rust-O-Mod Pickup Build thread
    Post by hammerinhank Sat Nov 26, 2022 9:32 am
    I looked and pondered at least a 1000 times before I started cutting.
    Had another question if you don't mind me picking your brain.  How did you do your engine mounts?  Looks like you replaced your frame rails so that should be pretty beefy.  I'm keeping stock stamped rails.  They are solid, no rust but I've heard they're prone to fatigue cracks.  I have the big engine cross member but wanted to avoid using it to keep the under side looking cleaner so I am thinking about welding doublers along the rails and building perches to for the motor mounts to sit on. What do you think?
    13-ball
    13-ball
    Number of posts : 87
    Registration date : 2020-07-23
    1961 Rust-O-Mod Pickup Build thread - Page 4 Empty One Piece Power Windows
    Post by 13-ball Sat Dec 03, 2022 2:36 pm
    I'm starting to see why guys give up and just screw on a piece of plexiglass....
    I had the bright idea that putting in a one piece glass was going to be a lot simpler than redoing all the mechanisms and seals in the roll-up and vent windows.  Seemed like a lot less parts.
    This has been a ton of work - not sure if I'd do it again.
    Here's the brace (cross piece with round hole) where the vent window stuff anchors.  Gotta cut it out.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221124
    The vent window and the roll-up are on 2 different planes.  I learned the hard way you gotta get this line straight.  I tried first to get the glass to fit in the funky gap.  It never looked good and would always interfere at one end or the other.
    It's surprisingly difficult to straighten out this slot.  Both sides of the glass need to be worked out.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221123
    There's nothing but air in the front part where the vent window stuff was.  The new, longer beltline fuzzy needs something behind it.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221126
    Added some metal to both inside and outside so the fuzzies can be screwed down.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221125
    There's also this divot where the vent frame comes through.  If it was getting a shiny paint job this should probably be filled and straightened.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221127
    Once I learned about getting the opening straight the second door was kind of easier.
    13-ball
    13-ball
    1961 Rust-O-Mod Pickup Build thread - Page 4 Empty 1 piece windows
    Post by 13-ball Mon Dec 05, 2022 3:28 pm
    The one piece windows are finally coming together.  They still need some fitting and refining.  The glass may need to be reshaped a little bit to get the corners to seal up.
    But, pretty psyched to see some visual progress. After seeing it in reality, (other than just dreams) I think it looks much better than the vents.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221212
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221210
    1961 Rust-O-Mod Pickup Build thread - Page 4 20221211
    gsnyder67 and mhbsmark like this post
    Post by vanny Mon Dec 05, 2022 4:02 pm
    Wow, that Really changes the look completely! I like what was hiding in your mind! Thanks for having the cahones to follow it through! Nice execution!!!
    13-ball
    13-ball
    1961 Rust-O-Mod Pickup Build thread - Page 4 Empty Glove box
    Post by 13-ball Tue Jan 24, 2023 8:01 am
    Is it my imagination or have those cardboard glove boxes gotten really expensive?
    My old Chevy truck has one of the repo cardboard ones and it's terrible.
    I had a piece of 18 ga. about the right size so I made a steel one.  It may be the most heavy duty thing in the whole front of the truck.
    1961 Rust-O-Mod Pickup Build thread - Page 4 20230120
    Still needs the sides...
    1961 Rust-O-Mod Pickup Build thread - Page 4 20230121
    Fits ok!
    vanny and gsnyder67 like this post
      Current date/time is Thu May 09, 2024 3:19 am
