+16
66mnecotruck
SteelyVan
Dawgboy
20 posters
    Dawgvan: A '64 A100 Build thread
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    Dawgvan: A '64 A100 Build thread Empty Dawgvan: A '64 A100 Build thread
    Post by Dawgboy Sun May 26, 2013 9:14 pm
    I Decided I would start a build thread for my 1964 Dodge A100 van. I have done a bit already, including new shocks, a full wiring harness, and a complete going through of the cooling system.
    On this post I am going to concentrate on what I did about my non-functioning gauges. They were all fried with the ammeter blowout before I bought it and then the post new harness failure of the dash Voltage limiter. I had a spare cluster, but as you will see, it's also doa...
    First the van
    Dawgvan: A '64 A100 Build thread Photo_zps125c9f66
    The Door decal remains(Palomar Mountain Observatory)
    Dawgvan: A '64 A100 Build thread Photo_zps69d346e7
    And it's original owners.
    Dawgvan: A '64 A100 Build thread Photo_zps91f2a439
    So The Limiter fried, and I made my own for $4.00 in parts from Radioshack
    Dawgvan: A '64 A100 Build thread Photo_zpsac51c291
    Installed on the back of the cluster. Note the 18Ga. brass plate for a heatsink. I also cut off the 12 volt side of the dash bus at the gas gauge.
    Dawgvan: A '64 A100 Build thread Photo_zpscc3b9d9f
    I got it all wired up, verified that the original temp gauge was shot, Verified the boneyard unit worked, and promptly destroyed it by pulling too hard on the wire...
    Dawgvan: A '64 A100 Build thread Photo_zps8e5fc961
    Back to the drawingboard. Went to Carquest and bought a cheap electric temp gauge kit. Decided to add a volt meter from an airplane I had lying around. I cut the dash out where it was damaged by the PO. Idea here is this is temporary, Going to either have the original cluster rebuilt, or get all new quality gauges, either way, where I cut the grill will eventually be filled with a stereo. So... Here goes my first A100 hack...
    Dawgvan: A '64 A100 Build thread Photo_zpsd4365b48
    Dremels are great!
    Dawgvan: A '64 A100 Build thread Photo_zps11282f5e
    Test fitting and cuts done with a hole saw and a jewelers saw in 18Gauge copper.
    Dawgvan: A '64 A100 Build thread Photo_zpsfa6c564d
    Dawgvan: A '64 A100 Build thread Photo_zps7d1b35ff
    Dawgvan: A '64 A100 Build thread Photo_zpsd99229b2
    Wiring harness
    Dawgvan: A '64 A100 Build thread Photo_zps854fcc72
    And here it is working. Added a 12vdc powerport on the bottom and also terminated out a setup for dual USB from the 5vdc circuit that I will install a little later.
    Dawgvan: A '64 A100 Build thread Photo_zpsf6612086
    Dawgvan: A '64 A100 Build thread Photo_zps741ceb46
    What did I learn? I heat up to 210 on steep climbs but tends to run at 190. Cool
    Dawgboy
    Dawgboy
    Dawgvan: A '64 A100 Build thread Empty Re: Dawgvan: A '64 A100 Build thread
    Post by Dawgboy Mon May 27, 2013 9:13 pm
    Here is some more of my Ghetto fabulous work from today. I was given these seats from a '73 Super Bee, and they are much superior to the ones the van came with. The leather is cracked, and there are some rust stains, but In they went today after several good scrubbings.
    Old ones
    Dawgvan: A '64 A100 Build thread Photo_zpsbe166a50
    New ones. Before cleaning
    Dawgvan: A '64 A100 Build thread Photo_zps4e668bee
    Instslled
    Dawgvan: A '64 A100 Build thread Photo_zps09f6ff8a
    My "custom" Tee-shirt cover for the driver seat. I hog ringed them onto the seat.
    Dawgvan: A '64 A100 Build thread Photo_zps906129a2
    Number of posts : 714
    Post by Gothboy Tue May 28, 2013 4:52 am
    Every little bit gets you one step closer to having a wonderful shiny toy to drive around! Looking like progress amigo! Smile
    Number of posts : 3046
    Post by RodStRace Tue May 28, 2013 7:06 am
    Progress!
    Those aren't OE 73 Super Bee seats. They were high backs without the lumbar supports shown.
    Dawgvan: A '64 A100 Build thread RS_Cars_834_Interior_1515_1272651590
    Post by Joe Van Tue May 28, 2013 7:50 am
    LOOKS like you have a Good Solid van there and a rare one also. looking good keep the pictures coming.. cheers ..
    Dawgboy
    Dawgboy
    Post by Dawgboy Tue May 28, 2013 12:32 pm
    Well, I was told that's what they were, but I was not sure... The important part is they were free. I will keep 'em until something better, and not quite so tall shows up. I am very happy with how they feel, but they are 4 to 6 inches thicker than the OG seats and that makes my view out the windshield different enough that I am already looking for better.
    Number of posts : 322
    Post by Wheelie Thu May 30, 2013 6:44 pm
    Like I always say, If its free then its for me. Lookin good
    Post by vanny Thu May 30, 2013 7:49 pm
    Lookin good Dawgboy. Now you've got momentum on your side! Keep it going and keep the pics coming. Thanks, Vanny.
    Dawgboy
    Dawgboy
    Post by Dawgboy Thu Jun 06, 2013 4:41 pm
    Figured out why my fuel usage was so high, fuel was shooting out the bottom of the fuel pump. Still, it's better than a jeep, which would shoot it into the crankcase.
    Another great thing about this van is its rock simple and eazy access just by pulling the seat and the side panel.
    So off to Carquest for a $20 lifetime warranty pump and it's no longer a flaming death trap.
    There is this weird fuel line back flow dealio, but I could not reinstall due to a difference in fitting size. I will re- address that later.
    I wonder if the whole 'dies as you pull up to a light' syndrome was that last 2 feet of line depressurizing as the engine revs dropped and the bad fuel pump would slow enough for the line to drop all it's fuel back down the line?
    Dawgvan: A '64 A100 Build thread Ahutuha9
    Dawgvan: A '64 A100 Build thread Rujamene
    Dawgvan: A '64 A100 Build thread 5u9umy8a
    Post by vanny Thu Jun 06, 2013 4:50 pm
    Nice detective work and fix!
    Dawgboy
    Dawgboy
    Post by Dawgboy Thu Jun 20, 2013 9:10 am
    Ordered a set of these for the van today. Hopefully they will mount ok.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390606256302
    Dawgvan: A '64 A100 Build thread Westco11
    Post by Gothboy Thu Jun 20, 2013 9:23 am
    looking good amigo! Smile
    Post by vanny Thu Jun 20, 2013 10:17 am
    Those look like the same ones that Surfer Guy 65 (Scott) installed on his recently. Looking good!
    Number of posts : 1686
    Post by westcoastvanner Fri Jun 21, 2013 1:28 am
    Post photos when you get them installed.
    Dawgboy
    Dawgboy
    Post by Dawgboy Fri Jun 21, 2013 7:53 pm
    Arrived in 1 day! Amazing!
    I installed the right side today as the original was broken. Seem a little big...
    Dawgvan: A '64 A100 Build thread Syzyzyma
    Dawgvan: A '64 A100 Build thread Zymadyqa
    Dawgvan: A '64 A100 Build thread Puzyha2y
    Dawgvan: A '64 A100 Build thread Ysyse9es
    SteelyVan
    SteelyVan
    Number of posts : 112
    Post by SteelyVan Sat Jun 22, 2013 6:44 am
    This is how I did mine (on a Chevy). You have to cut the inner tubes to get mirrors to tuck in.  To make them plum, I had to chop the bottom outer tube completely off.
    https://vintage-vans.forumotion.com/t30406p555-the-surfing-guy-s-65
    SV
    Dawgboy
    Dawgboy
    Post by Dawgboy Sat Jun 22, 2013 6:35 pm
    Sweet! Thats what I need to do. looks to be the identical mirror and I think look like Dumbo's ears right now...
    Dawgvan: A '64 A100 Build thread Photo_zps7c8a99ee
    Dawgboy
    Dawgboy
    Post by Dawgboy Sun Jun 23, 2013 5:23 pm
    Ok, ghe back windows are flapping and the latches are bad. Going to replace the whole door eventually, but for now, in go the "new style" frameless openable glass I got at the boneyard in Oceanside, ca with the generous help of Gothboy.
    Dirty junk
    Dawgvan: A '64 A100 Build thread Apu3ydu9
    Limpia mucho
    Dawgvan: A '64 A100 Build thread Gamunabu
    The old and new
    Dawgvan: A '64 A100 Build thread Syjesu9u
    Slight hardware issue, had to re drill the outer holes
    Dawgvan: A '64 A100 Build thread Avyby4aq
    Dawgvan: A '64 A100 Build thread Sagu9yvu
    And done. Just need to buy the window seals and do the other 3...
    Dawgvan: A '64 A100 Build thread 8ura7ena
    Post by vanny Sun Jun 23, 2013 6:27 pm
    Cleaned up real nice! Nice piece of work!
    Post by westcoastvanner Sun Jun 23, 2013 11:09 pm
    How did you drill the glass without it cracking or breaking?
    Dawgboy
    Dawgboy
    Post by Dawgboy Sun Jun 23, 2013 11:21 pm
    No drilling required, the glass came out of another van with all the hardware included.
    Post by westcoastvanner Sun Jun 23, 2013 11:27 pm
    What vehicle and year did you get the frameless windows out of?
    Dawgboy
    Dawgboy
    Post by Dawgboy Mon Jun 24, 2013 4:42 pm
    Think it was a 67-69 glass. It was from the junkyard.
    Dawgboy
    Dawgboy
    Post by Dawgboy Wed Jul 10, 2013 2:02 pm
    Bought a Godspeed Project 14" auxiliary cooling fan for the van. Going to use it as a pusher and it will be on the front of the radiator. I know this is a smaller fan, only 1500 CFM, but I am leaving the non flex original fan in place. Ordered Sunday and it's here already. Also added another fuse panel for the "house" wiring. This will be for always on stuff.
    Dawgvan: A '64 A100 Build thread 5ymu4y4y
    Dawgvan: A '64 A100 Build thread Rupyhu9e
    Dawgvan: A '64 A100 Build thread Sanupu7y
    Dawgvan: A '64 A100 Build thread Jebava6u
    Godspeed 14" fan
    Post by Gothboy Thu Jul 11, 2013 5:24 am
    Wow! Vantastic buddy! Im glad to see all the progress on your van! Its looking great!!! Oh, and if you're ever in my neck of the woods, I have van doors since you said you wanted to replace one of yours. You can see which one you want and its yours. Have a great day!
      Current date/time is Thu Mar 28, 2024 5:13 am
