    64’ Wire Harness
    StuartG
    StuartG
    Number of posts : 28
    Registration date : 2019-05-10
    64’ Wire Harness Empty 64’ Wire Harness
    Post by StuartG Sat Dec 12, 2020 7:38 am
    I need to upgrade and replace my fifty year old wiring for my
    64’ g-10. Looking for a Company or p/n that sells all the wiring or harnesses I need from the fuse block to the tail lights. Any help would be much appreciated
    Thanks
    SteelyVan
    SteelyVan
    Number of posts : 112
    64’ Wire Harness Empty Re: 64’ Wire Harness
    Post by SteelyVan Sat Dec 12, 2020 3:59 pm
    Unfortunately, there are no kits specifically for our vans (that I'm aware of). I would recommend looking at Painless wiring....and other similar companies. A GM universal type (kit) will use similar (if not exact) colors and proper gauge wiring. A 60's GM pick-up kit, for instance, will/may be even more specific with included correct connectors depending on price-point. Ya gotta look around and see what you like and dislike. Make a list of x-tra circuits and features that you'd like in addition to what came stock. Think ahead
    Cooling fan?
    HEI?
    Internally regulated/One Wire/Higher Amp Alt?
    Robust sound system?
    Inverter?
    A/C?
    Hot tub?
    etc..etc
    I got a Ron Francis GM Express kit...(to me) worth every penny.
    Save everything from/off of old harness
    StuartG
    StuartG
    Post by StuartG Sat Dec 12, 2020 8:00 pm
    Thanks much appreciated 👍
    Number of posts : 698
    Post by Russell Sun Dec 13, 2020 7:46 am
    StuartG wrote:I need to upgrade and replace my fifty year old wiring for my
          Thanks
    There are only 5 or 6 wires going back to the rear? Up through the pillar and along driver's side of roof to interior lights,(hot wire) gas gauge sender, tail and license lights, 2 turn signal,(also are brake lights)
      Current date/time is Sun Apr 28, 2024 4:38 am
