    ? Wire Blow Off
    Number of posts : 864
    ? Wire Blow Off Empty ? Wire Blow Off
    Post by Casimier Mon Feb 06, 2012 6:07 am
    ? Wire Blow Off
    Anyone ever have wires blow off the top of their distributor when starting?
    It's usually the coil wire and a plug wire off the distributor.
    ? Wire Blow Off Empty Re: ? Wire Blow Off
    Post by Twinpilot001 Mon Feb 06, 2012 6:38 am
    can happen - usually due to wires not being secure in cap.push them down hard. they should sort of lock in.
    Post by Casimier Mon Feb 06, 2012 6:50 am
    I figured as much...I've pushed them down hard...time and again
    they keep popping off...I guess it's time for new wires
    thanks
    Number of posts : 3046
    Post by RodStRace Mon Feb 06, 2012 7:18 am
    Slide the boot back a bit and try to slide the wire in until the clip 'clicks' into place. You may have to spread the clip a bit. Then slide the boot down, squeezing the top a bit to keep from trapping too much air inside.
    If it is popping off only when starting, make sure you aren't dealing with a worn bushing. Remove the cap and wiggle that shaft. Too much slop will allow cranckase pressure to get into the cap.
    Post by Casimier Wed Feb 29, 2012 9:47 am
    I pryed the wire end to make it bigger...
    seemed to do the trick
    Thanks Guys
      Current date/time is Sat Apr 27, 2024 8:33 pm
