    Windshield washer tee
    Number of posts : 405
    Windshield washer tee Empty Windshield washer tee
    Post by Keith D Fri Mar 27, 2020 5:42 pm
    I am putting in a original style windshield washer system (foot pump) in my van. It did not have one in it when I got it so I am building the system from parts that I have found over the years.
    What I am looking for is a source for the tee that goes between the very small hoses to the chrome windshield "squirters" and the larger hose that goes to the check valve on top of the plastic bottle.
    I have not been able to find the tee at any local parts stores, if anyone knows of a source for this plastic tee I would appreciate it.
    Thanks...Keith
    Number of posts : 1558
    Windshield washer tee Empty Re: Windshield washer tee
    Post by OutofSight Sat Mar 28, 2020 5:26 am
    Do you have a picture of it?
    Number of posts : 8729
    Post by dix Sat Mar 28, 2020 8:44 am
    i would try hardware stores in plumbing section
    Post by Keith D Sat Mar 28, 2020 10:52 am
    OutofSight wrote:Do you have a picture of it?
    I don't have a picture as I don't have one, it is P/N 1-82-8 in the illustration. The two legs that go to the squirters are really small. I have looked everywhere that I can think of with no luck.
    Windshield washer tee Scan0110
    69
    69
    Number of posts : 434
    Post by 69 Sat Mar 28, 2020 1:52 pm
    Post by Keith D Sat Mar 28, 2020 2:04 pm
    Thanks... I saw this site before it does not have the right size.
    The Tee should be 1/8" on the two sides that go to the squirter nozzles and 3/16 on the leg that goes to the washer bottle's check valve. That's what I measured the pieces at.
    69
    69
    Post by 69 Sat Mar 28, 2020 2:48 pm
    Would probably not be perfect re squirting pressure, but how about using a 1/8" on all three sides and fill up one of those with duct-tape to fit the 3/16" hose?
    Or, Use a 3 sided 1/8" and use a short piece of 1/8 hose fitted with 3/16 on the other side? silicon hose should work with a sitution like this.
    Post by Keith D Sat Mar 28, 2020 9:32 pm
    Post by OutofSight Sat Mar 28, 2020 10:45 pm
    Nice!
    Dan Scully
    Dan Scully
    Number of posts : 254
    Windshield washer tee Empty Tees
    Post by Dan Scully Sat Mar 28, 2020 10:52 pm
    Mc Master Karr is another source , metal plastic etc.
    https://www.mcmaster.com/tees
      Current date/time is Fri Apr 26, 2024 11:09 am
