    1st gen windshield washer
    Number of posts : 1778
    1st gen windshield washer Empty 1st gen windshield washer
    Post by m1dadio Tue Feb 05, 2013 5:35 pm
    Is the 1st gen windshield washer hose supposed to have a check valve or something to keep the pump wet?
    Mine works fine after its been primed but looses the prime after a day or so and then won't draw the fluid from the bag until I prime it again.
    whats missing, what do I need here?
    M1D
    1st gen windshield washer Empty Re: 1st gen windshield washer
    Post by donivan65 Wed Feb 06, 2013 7:44 pm
    If a pump won't pump, I would think it is sucking air or the suction valve is not shutting off,,,,If you got one of these electric ones, you might be able to remove the pump cover and see if you get lucky and there is only some dirt in it that you can clean out.....
    1st gen windshield washer Washer10
    Post by donivan65 Wed Feb 06, 2013 8:21 pm
    ,,,,here is the repair,,,,,,
    1st gen windshield washer Repair55
    Post by m1dadio Wed Feb 06, 2013 9:31 pm
    Is that the pump I should have? that looks like it attaches to the windshield wiper motor? My WW motor is a two speed but has no previsions for a pump attachment. The pump I have is a small motorized rotary pump inline on the hose from the bag. however it clips into a clip that is attached to the body and it looks original but maybe it isn't?
    like this one
    1st gen windshield washer Pump10
    M1D
    Post by donivan65 Wed Feb 06, 2013 10:30 pm
    Yours sure looks like an aftermarket one,,,,,,and those little 12 volt washer pumps are probably more square looking now.......
    Post by donivan65 Wed Feb 06, 2013 10:41 pm
    1st gen windshield washer Was_pu10
    Post by donivan65 Wed Feb 06, 2013 10:59 pm
    1st gen windshield washer Washer11
    Post by m1dadio Thu Feb 07, 2013 7:39 pm
    The problem is the pump wont stay primed, There was a check valve in the line but the WW fluid attacked the diaphragm and it stopped working. Probably because it was made for air and not ammonia based washer fluid. I cant find a good check valve anywhere.
    M1D
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Fri Feb 08, 2013 11:47 am
    I love those old footpumps. Had one on an old Dodge GT. Seem to be hard to find.
    Am hoping for somebody to come out with a really simple and sturdy vehicle with foot pumps, window cranks and few if any electronic gizmos. Oops, I have one already-my ChevyVan!
      Current date/time is Tue May 07, 2024 9:17 am
