    Gen 1 and Gen 2 side profiles match?
    TomBrown63
    TomBrown63
    Number of posts : 19
    Registration date : 2014-04-26
    Gen 1 and Gen 2 side profiles match? Empty Gen 1 and Gen 2 side profiles match?
    Post by TomBrown63 Mon Nov 18, 2019 11:22 am
    I have a 65 GMC handi-van where a tree fell on the roof years ago, damaging the roof, sidewall and horizontal steel where they meet.  It even put a small kink in the two upright 'beams' inside.  I see a  GEN 2 in a local junkyard that has a good solid drivers side, does anyone know if the profile matches the Gen 1 window van so I could make it into a display van?
    https://servimg.com/view/20136585/1Gen 1 and Gen 2 side profiles match? Img_5610Gen 1 and Gen 2 side profiles match? Img_5711
    Number of posts : 698
    Gen 1 and Gen 2 side profiles match? Empty Re: Gen 1 and Gen 2 side profiles match?
    Post by Russell Mon Nov 18, 2019 3:05 pm
    I think they are the same except for the front? Let me know if you are going to sell those pop out windows. One of my friends needs some for his Van.
    I think display vans are cool.
    TomBrown63
    TomBrown63
    Post by TomBrown63 Thu Nov 21, 2019 8:47 am
    Thanks Russell, I'll be doing some detailed dimensions so I can compare, and I'll look you up if I have the windows available. I'm working on drivetrain first.
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Tue Nov 26, 2019 9:27 pm
    The cab roof skins are different as is the front ahead of the doors...…. In the area you are showing, they are the same..... The required bodywork needed is going to cost way more than the van's value..... Way better to find a better body as a starting point...
    chrlsful
    chrlsful
    Number of posts : 184
    Post by chrlsful Sun Dec 27, 2020 2:53 pm
    so the 1st 3 yrs are the same wheel base as 2nd gen (hight too?)
    3D Kustoms
    3D Kustoms
    Number of posts : 5
    Registration date : 2015-08-02
    Post by 3D Kustoms Sun Jan 24, 2021 11:31 am
    Cut out and replace what is dented and keep the original body forget the advice about more than its worth, if that stood true none of us would be working on keeping these alive. If you like it fix it and keep it on the road.
    chrlsful
    chrlsful
    Post by chrlsful Sun Jan 24, 2021 11:53 am
    "...a better body as a starting point...."
    not readily available.
    Some sections require english wheel &
    other specialty equp. Untill all older vehicles
    get the respect a few do, we will not find sources
    of after market sheet metal (U can build a 'stang or
    bronco from scratch today this way) for these rare art-
    work-on-wheels. Best bet? patch panels, bench built as
    far as I can do or see...I just ask my Q to see if I can short
    cut it & go to the junk yrd for less wrk & more availability. We
    call it 'swap-ins".
      Current date/time is Fri Apr 26, 2024 9:14 pm
