Keith D wrote:Again to clarify hometeam states that he has a gauge not a light, correct?
If this is not correct for the motor /year van as it came from the factory it sounds like someone replaced the gauge cluster with one that came with a oil gauge and had ran a oil pressure line somewhere to the engine or pump.
I would have deleted my previous post if I could figure out how....
Doing research I stumbled upon this webpage which states an oil pressure gauge was indeed an option.
"SELECTED OPTIONAL EQUIPMENT
225-cubic-inch, 140 horsepower Slant Six engine
318-cubic-inch, 210-horsepower Dodge V8 engine
Heavy-duty, 3-speed manual transmission (Model A745)
Three-speed LoadFlite automatic transmission (with dashboard-mounted selector)
Anti-spin differential
One-quarter oil-bath air cleaner (V8 only)
37-amp alternator (6-cyl.), 46-amp or 60-amp alternator (6-cyl. and V8)
59- or 70-amp-hour battery
Two-tone paint
Chrome finish, front and rear bumpers
Chrome finish (or enameled) front bumper guards
Tinted windshield glass
Auxiliary heater (hot water) for the cargo compartment
Dual electric horns )replace single horn)
Interior rear view mirror
Dual Jr. West Coast rearview mirrors
Transistorized radio
Self-retracting door step below curbside cargo doors
Passenger’s seat, full-foam, bucket-style with seat belt
Passenger armrest
Undercoating
Stainless steel wheel covers
Oil-pressure gauge
http://www.dodgea100.com/a108-brochure/I looked thru my service manual but it didn't show any diagrams of the oil line. It did have a procedure to check the oil pressure gauge in section 8, "electrical", page 8-59. Yes the oil gauge is mention under electrical due to it being lumped together with "electrical" dash gauges.
As others have said, It most likely attached to the fitting the sending unit attaches to, then ran underneath to the front of the floor then up to the dash. That location on the engine would give the most accurate pressure reading. I remember from earlier years I've installed oil pressure gauges on a 350sm at the top back of the block, where the electrical sending unit is/was located.
A new rubber line should work just as well as the original did back in the day. If you're that worried about using rubber, you can probably get a stainless steel line custom made.
I hope you get it(or already have it) figured out!
