Eric Howard
Engine/doghouse wiring harness
Eric Howard- Number of posts : 11
Registration date : 2017-05-27
Hey everyone my wiring harness from the doghouse burnt up. Can't seem to find an aftermarket one. I'm very new at this and don't know anything about electrical. Didn't know if there was a cheap fix for this. Any suggestions would help alt. Thanks everyone
m1dadio- Chevy Guru
- Number of posts : 1778
Re: Engine/doghouse wiring harness
Welcome to the site
No new or aftermarket replacements available. you need a used one.
Look in G parts for sale and ask the people parting out vans or if they are near a junk yard they might go get you one.
You need to identify your van, year,model, engine and trans.
do you need the charging system harnes which is seperate
M1D
M1D
Ill check the charging cable. There's a junkyard in anymore Nebraska. There's two different yards by two brothers. They have almost everything vintage its car heaven. Thanks much for the reply. Let me know if you are looking for specific parts . Ill take a look for ya.
Thanks again
Eric
Thanks again
Eric
,,,so what kind of van do you got,,,,,,an old one,,,,,a vintage one,,,,,4 cylinder,,,6 cylinder,,,,,8 cylinder,,,,1st gen,,,,,,2nd Gen,,,,,,3 speed trans,,,,4 speed,,,,or automatic ,,,,,,,we need to know what you are talking about if you want help,,,,,,,,,
Sorry about that. It's an 1965 chevy 6cylinder automatic
I can tell you how to fix it,,,,,,the wiring loom comes from the dash into the doghouse to this connector right below the carburetor,,,,,,do you have that connector there,,,,,,,and does anything work,,,,,,just a few wires there,,,,,,horn, alternator, oil sender, starter, coil and power to dash,,,,,,,,does your van run,,,,,do you have pictures,,,,,why is it burnt up?
When did this happen,,,,,did it ever run,,,,,,,did you put a good battery in it and see what works,,,,,,the horn relay in this picture is the brains of the wiring circuit,,,,,,those 2 screws on it send out the power through the red wires,,,,,DO YOU HAVE IT,,,,,ARE THE WIRES ON IT BURNT UP,,,,look on the starter solenoid where the positive battery cable hooks up to it,,,,,,,do you see a wire from there going up to one of those screws on the horn relay? Do you understand what I am talking about so far? Are you, or someone going to be able to replace a couple of wires?
Ya a little I understand. It was running good then it just wouldn't turn over. It kept draining the battery so I got a brand new one and it drained it too. At one time I charged it and the temp gauge wouldn't shut off. I went to a junk yard in Nebraska and found two wiring harness and a nice gauge cluster. I'm gonna go through it Sunday and my friend is coming to help me. I'm actually learning quite a bit from all your guys and different forums. I like that everyone is a community and happy to help. I got out of the army awhile ago and it's nice to see the camaraderie here
Thank you
The main feed on these old girls is terribly undersized and quite often it will get hot and take out other wiring with it. It often shows up at the harness plug inside the doghouse. Like Don says up grading is best. To help yourself using another intact original harness. Do not put any accessories through it. Set your self up with an additional fuse block and feed that separately. The use of relays and such work out pretty well for this.
gfleduc- Number of posts : 367
Wiring Harness
Hi Eric
I sent you a private message
Thanks guys
Hey guys. I found a website Car Parts Discount.com. it has a wire harness connector. Smp wire harness s93. 1965 Chevy van g10 was wondering if this is the right harness. Thanks
VatoVan66- Number of posts : 3
Registration date : 2019-01-08
I have a 1966 G10 6cyl automatic transmission .. I need a new wiring harness what is the best route to obtain one ? EZwiring and start over new or ? I do have the horn relay and everything else under the doghouse that Im aware of .. Any info is appreciated
JackeFriend- Number of posts : 940
- Post n°19
I sent you a PM
