Alright, got the carb rebuilt and back on and the van is already running so much smoother!
This weekend's project is to remove the steering box and pop the valve cover off.
My question to you guys (with the 225 six) is, what method did you use to adjust your valves? There isn't a nut/bolt for me to grab onto the harmonic balancer to rotate the motor... Do you bump the motor over with the starter until you get close to TDC for the valves you are adjusting, or do you adjust the valves with the motor running? If the latter, how difficult is it to set the lash with the motor running, I've never tried?
Also going to check the valve seals while I'm in there. There is a bit of smoke at start-up that goes away after the engine warms up.
