    disc brake conversion kits????????????? expert opinions?
    ChevyVanMan1
    Number of posts: 225
    Registration date: 2009-07-19
    True, tho I have yet to weigh,,,
    Post by ChevyVanMan1 on Sun May 23, 2010 9:18 am
    True, tho I have yet to weigh all the components it all looks like the disk brake conversion will give me more unsprung weight. Yet not alot I guess and I doubt with and old buckboard suspension like on our earlies it will make much of a performance difference. Of course, I just putter around anyway.
    More concerned about rotational weight related to taking off and stopping because even tho unsprung weight is worse than suspended weight, I'm quite sure, in staight axled oldies like ours (more like a garden shed on wheels) a little unsprung weight does not make as much difference as rotational weight.
    Now that we are discussing it I will make some effort to weigh the caliper and mount to compare to the backing plate and brake assembly--unless of course somebody else has done it already.
    Thanks much to all for contributing to this disk brake conversion chat. Because there are so many choices of parts I am trying to stick to NAPA for simplicity and when finished I will post a complete parts list. I'm not holding my breath on that one :-)
    Sporto's 67
    Number of posts: 1
    Registration date: 2010-05-20
    Brake drum backing plate
    Post by Sporto's 67 on Tue May 25, 2010 4:49 pm
    If any one here could help me maybe ... I have a 67 chevy van and I am looking for a left front drum brake backing plate. Mine is split and I am moving soon and don't have time to put the disc brake kit on yet. Or even what kinda vehicle it might fit off of. Thanks for any help you can give me.
    Sporto
    Number of posts: 1225
    Registration date: 2008-05-20
    Re: disc brake conversion kits????????????? expert opinions?
    Post by Scott on Tue May 25, 2010 8:14 pm
    Ask econopoor, he just cut one up..
    Not sure if the plates were any good or not.
    MysteryMachine
    Number of posts: 23
    Registration date: 2010-09-14
    Post by MysteryMachine on Wed Jan 05, 2011 9:12 pm
    ive been wanting to replace my brake disc rotor for a long time now. i saw this video about
    how to replace a brake disc (rotor) and want to know if this can help me too. hope you reply.
    Number of posts: 5627
    Registration date: 2008-05-12
    Post by donivan65 on Wed Jan 05, 2011 10:31 pm
    So what kind of vehicle are you talking about? Do you just want to replace a worn rotor or replace a drum brake system with a disk brake system?
    Number of posts: 308
    Registration date: 2009-10-04
    Post by panelmanrd on Sun Jan 09, 2011 3:23 pm
    one of the guys in our club installed the m1d syle front disc brake set
    up on his 67,90 is does stop dramaticlly better no brake fade or pulling
    side to side, he used the stock 67 van master cly and perpot valve
    with no residual valves external of the mc, works fantastic.
    had to move the sway bar mount to the top of the axle and move the
    frame mounts to the rear using the rear hole as the front and installed
    nut inserts for the rear bolts. we did not move the shocks at all.
    Number of posts: 981
    Registration date: 2008-10-06
    Post by m1dadio on Wed Jan 12, 2011 9:42 pm
    New Disc brake options for 2011.
    #1 M1D80TA bracket
    Feed back information has enabled me to further improve the M1D80TA disc brake bracket, installation and setup. I have now defined one set of Calipers, hoses, banjo bolts and pads that work best for this bracket and the bracket has been changed to improve caliper bleeding. These parts are available in different qualities at different prices and the larger/stronger police/service pads can also be used. This disc set up uses an 11.16” Hat type rotor. It requires some mechanical aptitude for initial installation. Future brake maintenance and pad changes are cheep and easy. This set has an installed radius of 6.65” and the caliper is close to the outside wheel mounting surface so Many 14” rims will just fit and some will not depending on their internal shape.
    One advantage to the hat type rotor is service and maintenance and almost never needs machining. Unlike the solid one piece rotor which traditionally has to be machined if warped.
    You will clean up, prepare and re-use your hubs with replacement wheel studs installed.
    This set up will widen your vans track width but only by approximately 1/8” each side.
    M1D80TA bracket
    #2 M1DK10N bracket
    This front disc set up uses a one piece 11” 74 Nova rotor. This set has an installed radius of 6.5” and the caliper is quite inboard so most 14” rims will fit as the 74 Nova came factory with 14” rims but some will not depending on their internal shape. The M1DK10N takes basic mechanical skills and equipment and will feature way less work to install then the other options. Much less modifications to the van then previous nova rotor installations no moving the shocks or machining of steering arm or anything like that. But this rotor will off set the wheels out by just over 3/8” on each side. In alignment terms, that’s a lot! But many aftermarket wheels do worse then that. Aftermarket wheels can be purchased to correct that off set back to original track width.
    With this bracket I will provide this option; You can purchase the manufactured brackets or a scale template on this design so the budget challenged Vanner with fabricating shills can make the brackets themselves. Comes with a parts list of specific calipers, hoses, banjo bolts and pads to use or the larger/stronger police/service pads can be used as well.
    M1DK10N bracket
    Note: Widening the tread width of the front wheels changes the steering geometry in too many ways to explain hear. You may want to research the subject your self. The usual effects are; more steering input force is required, especially at stand still steering, abnormal tire ware, wheel fit in fender wells and if the width is excessive there can be increased loss in strait line stability driving (wonders more and feels like it grabs every crack in the road).
    #3 M1D2KV Bracket
    I am also designing a 12” rotor disc brake set up,. The M1D2KV set up will take a little more work on the initial install and requires larger wheels. Front braking efficiency will be 11% greater. My 15” aluminum wheels just fit but I have to move the balance weights.
    It will use a smaller caliper that has a smaller piston area. So a different master cylinder then the other conversions will be needed on this application. It will also have smaller surface area pads so will not get as much mileage out of the pads as compared to the other choices.
    Note: All disc brake conversions require changes to the rest of your vans brake system additional to changing the brakes at the axle. The amount of and quality of change required/desired and its associated cost varies widely depending on your specific van and what you want in the end. Changes will include but are not limited to, the master cylinder, addition of residual valves and proportioning valve and new lines. You need to look into what is involved to convert your vans brake system in a correct and safest manner.
    I read and hear other Vanners who claim “they didn’t need this part or that part and the old line and master work fine with the disc brakes”. It is my personal opinion that they probably don’t and never will know how much improved their system could be if they applied the recommendations to their van. When it comes to your brakes you must educate yourself enough to know what you are doing and this is not the area to go cheep. If you are considering repairing or modifying the brakes on any vehicle, you need to know legal authorities will hold you 100% liable and financially accountable for claims made resulting from failure of that brake system, assuming they can prove you did a repair or modification to that vehicles brake system.
    Lets clear up the “How much” question.
    I keep getting asked the un-answerable question!
    “How much will it cost to change my van to disc brakes?”
    The answer varies greatly depending on many variables, like your individual answers to the following…..
    Year of your van?.
    Van model?
    Sway bar? What year sway bar? Aftermarket bar?
    Price of parts in your geographical location. A big price difference on this one!
    What quality of parts do you choose, parts come in several qualities/prices , “white box” ? Name brand? On line? higher priced aftermarket parts? Or bone yard parts?
    How old are your lines and hoses do they need changing?
    What type of rear brake mods? Are you going rear discs? If so that’s another whole can of worms that changes everything else.
    Overhaul of rear drum brakes is needed!
    Park brakes? They need to work right!
    Which disc rotor set up do you want?
    Your mechanical and fabricating ability, do you have to hire help?
    Cost of hired labor and any machine shop or professional services.
    Do you have to replace your wheels that might not fit?
    Here are some prices rumored by others.
    The cheapest I have heard, some one said they did the conversion complete 4 wheel discs for $400.I think that was all junk yard parts and the person had much ability and equipment and a full shop.
    I spent over $2600 on my brakes. Four wheel power disc new everything, I have a full maintenance shop with everything. I’m sure if I lived in the USA I could have done it for about $1600 or less. I live in a place where the same $22 caliper at Napa in the southern USA cost me $54, and the southern states $34 master is $96 where I live, my rear calipers were $195 each for over hauled ones.
    The front disc conversion brackets and all should on average come in around $450 and up but can vary allot. And that’s cheaper then many aftermarket brake kits.
    The necessary master and lines and valves upgrade varies allot, could be as low as $100 or as high as $300 +.
    Rear discs conversion could be anywhere from $100 to $700 more or less.
    Power boosted brakes will add another $100 and up to 2K, who knows what ever depending on your mechanical ability.
    It all depends on what you have and where you want to go with it.
    It is probably reasonable to expect to spend $500 to $800 for the basic do it yourself disc/drum conversion.
    Anyway as you can see, you will be the one telling us how much it costs when you’re done.
    Additional Van modifications sometimes needed.
    In some cases the 2nd gen van needs additional modifications to the sway bar link mount at the axle. This was particularly a problem when the K5 Blazer calipers were used. Here are a couple fine examples.
    Original bracket:
    Modified bracket t
    Replaced bracket
    You could probably do this with a chunk of 2x2x1/8” angle iron
    Some Vanners who installed the M1D bracket on their 2nd gen report no problem at all with the sway bar.
    The 1st gen will need the Master cylinder mount bracket cut away to allow fitting a duel circuit master. A 1st gen with a sway bar will need the sway bar lowered at the frame mounts to clear the newly installed duel circuit master cylinder and the belly pan modified to clear.
    If your brake lines are more then ten years old you should replace then all including the flex hoses at this time. And rebuild your rear drum brakes.
    Some people also experienced a lot of problems getting their system to bleed correctly. Many Vanners had a low brake pedal feel. Some of which was a actual problem and some just had unrealistic expectations of how their brakes should feel.
    Even though these disc brake brackets will come with install instructions and a parts list; I highly recommend you read the article I wrote on brakes and service problems.
    If you would like any of these brackets please email me at m1dadio@shaw.ca
    Thank you
    M1D
    Post by m1dadio on Sun Jan 16, 2011 12:05 am
    If you wish to reduce unsprung weight you can get alluminum calipers from Wilwood that replace the standard GM calipers. (single piston pn 120-5861 ) or (duel piston pn D52).
    One thing about rotor vs drum wieght is the fact that the mass of cast iron required to stop a vehicle of a certain wieght is the same. The cast irom rotors should be near the same wieght as the cast iron drums. Its a matter relating to the science of braking, ability to absorb and disapate heat and the amount of heat transfer capacity.
    If you want to reduce that rotating weight you have to go to different materials. Lighter materials but that can still deal with the heat transfer requirments.
    M1D
    Post by m1dadio on Sat Feb 05, 2011 4:03 pm
    Disc brake brackets are finally available, almost!.
    See earlier in this thread for expanded descriptions.
    The M1DK10N brackets that use the 11” Nova rotors are ready. Certainly the easiest to install.
    I will also provide, for the financially challenged person with fabrication skills, a template of this K10N bracket with parts list and install instructions at a reduced fee.
    M1D80TA , an improved version of the earlier M1D brackets using the 79, 11.16” trans-am rotor takes a little more hand skills but is a better set up in my opinion. These brackets are suposed to be ready monday Feb 7th.
    The M1D2KV brackets using the corvette 12” rotor and a smaller caliper are ready. Although not road tested yet, I am installing them on my van tomorrow and expecting excellent results.
    If you are interested in having any of these brackets, email me at
    m1dadio@shaw.ca
    with your request and I will respond with the price and availability, most are allready spoken for.
    The parts lists and install procedures will be included with the brackets or made available electronically to those who demonstrate financial commitment.
    M1D
    Post by m1dadio on Sun Feb 06, 2011 12:07 pm
    A lot of people are asking about wheel size and “will they fit”.
    There are so many different wheels with so many different tires sizes that there is absolutely no way I can answer your questions about your wheels.
    Here is some information on the brackets.
    They are all have the same bolt pattern as the G van.
    Usually aftermarket wheels have more internal space, especially “machined mag wheels like slots and my eagle 117s and even weld wheels with the flat wheel disc. Factory steel wheels are a total hit and miss campaign, they are made for specific applications and no further comments can be made on them.
    The M1D K10N uses the 70-74 Nova that came with 14” wheels. That does not mean all 14” or 15” wheels fit! They have to be “disc brake wheels”. This set up is approximately R= 6.5”. But that’s not all there is to be considered this rotor offsets the wheels out more then 3/8” so that makes better clearance of the caliper inside the wheel but puts the wheel closer to the wheel well lip which might make larger tires rub. This set up also puts the caliper further inboard which usually means modifying the 2nd gen lower sway bar attachment.
    The M1D80TA set up uses the 79-81 firebird rear rotor. Because this set does not off set the wheel out near as much. Although that means the steering geometry is closer to stock and the wheels sit in the wheel well better; you likely need a cleaner space on the inside of the wheel to clear the caliper and bracket. This set is approximately R=6.72”. So a lot of 14” and 15” will fit but many may not. The 79 Trans-Am had 15” mag wheels.
    Because this caliper set up is narrower and more compact into the wheel it has been reported that 2nd gen sway bar mods were not required.
    The M1D2KV set up is 12” rotors with smaller calipers. Probably better suited for the 1” master cylinder. This set is R=7.1”, they just fit into my 15” mags with 1/8” clearance. Not likely too many 15” wheels will fit here but 16” and up should be no problem. This set up is even more compact and inside the wheel then any other so additional van mods are not likely needed.
    Hope this answers for you.
    M1D
    Number of posts: 2189
    Registration date: 2008-05-17
    Post by Digz on Sun Feb 06, 2011 1:29 pm
    Just as a note I am using a mid 70's 15" Pontiac Rallye II style wheel for a spare. it clears both my front and rear disc setup. is a 15x7 rim. It has a 3.75" backspace I believe. This is on the 79 firebird rotor set up.
    Additional service and install tips.
    Post by m1dadio on Sun Feb 13, 2011 8:50 pm
    Feb 13, 2011
    Additional general installation notes for initial; installation of disc brakes.
    #1 I found that the organic and semi metallic brake pads do not grab as well as the “metallic” brake pads.
    #2 All the brackets are deliver unfinished because every body wants to finish theirs to their own liking.
    #3 On all brackets: when fitting the caliper to the bracket and making sure the caliper moves freely. apply wheel bearing grease to the bracket and the caliper on the sliding surfaces as seen here..
    In this area.
    #4 Do not apply wheel bearing grease to the slide bolts, bushings or “O-ring. They are made of a rubber material that will degenerate rapidly with organic lubricants. Do grease these bolts, bushings and o rings with synthetic grease like the silicone dielectric grease supplied with some calipers which is the same stuff used under the module in a HEI distributor.
    #5 When and if you need to grind or belt sand the crusty chunks of your calipers to make your wheels spin free, don’t be shy to grind down the tops of the brackets if they are sticking up too high or hitting the wheel.
    Like on this earlier bracket that stuck up 1/16” above the caliper.
    #6 For the 80TA and 2KV set up that require hub perpetrations. It has been found that the flat surfaces of your hub may have stud installation damage or wheel bolt over torque damage that resembles a high spot directly around the stud hole. It is important for true running rotors to file the surface flat and check for flatness after installing the new studs.
    #7 It has been discovered that not all Van forgings and castings are the same. For that reason it may be necessary to file fit the bracket or steering arm or spindle mount where there may be discrepencies.
    Like this 1st gen steering arm that fit
    Post by m1dadio on Mon Feb 14, 2011 11:24 pm
    tech foot note
    In The new instructions and at other locations throughout the van sites I included imformation about useing a dial indicator to measure rotor run out and how to true the rotor with shims.
    What I did not say was that I actually don't bother doing that and never do so unless I am having a brake pulsation issue.
    All the disc brakes I have installed on these vans have never needed to be shimmed, so far.
    M1D
    Post by m1dadio on Wed Mar 09, 2011 7:59 pm
    Doo’s and don'ts Advisory: Thinking about getting disc brakes??
    I am hearing of many vanners who pre-buy calipers, rotors, hoses and other disc brake stuff with the intension of getting their brackets later.
    I highly recommend against that, for the following reasons.
    #1 some people change their mind or sell their van and the parts become worth almost nothing.
    #2 brackets and the recommended parts for them continue to evolve and your parts may end up being not the best choice.
    #3 some parts lists posted on the van sites are not accurate or not from the bracket designer.
    #4 the store bought parts expire their warranty and return ability as they age on your shelf.
    #5 some people change there mind about which brake set they want on their van and the brackets they get are not for the parts they bought.
    I recommend you;
    #1 buy the brackets first (especially when they are available, like now for example) and then don't go buying anything else.
    #2 you might choose to sell them at a later date if you change your mind or sell your van, like some have done.
    #3 buy the remaining store bought parts at the time you do the conversion. This gives you an opportunity to shop around and find best deals and avoid some of the pitfalls mentioned above.
    Thank you
    M1D
    Number of posts: 137
    Registration date: 2011-01-20
    Post by Lyrad on Wed Mar 09, 2011 8:09 pm
    All makes perfect sence. I will be ordering my brackets next week. Thanks for taking the guess work out of the transformation. It helps feeling confident in what you are about to do. Awesome
      Current date/time is Wed May 16, 2012 2:46 pm
