Hey folks, I've been lurking on this site for awhile but never posted anything. Gained a ton of knowledge from you guys already !
Bought a 66 Supervan with a pop top about a month ago and am loving it !
Basically to get this thing back on the road I had to rebuild the old Autolite carb and replace the vacuum advance diaphragm, minor points adjustment, etc...
The engine seems to run great but seriously lacks top end power, and I'm only getting 10mpg.
I'm not seeing or smelling any fuel leaks and I'm kinda stumped as far as the gas mileage goes.
As far as top end power, it seems like that may be as good as it gets with that little carb.
Ok, so here's where I'm at ... Is there any intake out there that will fit in my doghouse with out cutting into it ? After searching like crazy I'm coming up with nothing .
So my other option was to buy the single to double barrel carb adapter and install a weber (which I already have ) I realize I'd be shoving more fuel through the same small hole, but is this my best option ? Did anyone manufacture a 2 barrel manifold ?
Again, I don't want to modify my doghouse. Any insight would be much appreciated.
thanks
thanks
