Found this 1965 DCW model 89D in the middle of no where out in Colorado. Per the VIN it was originally sold out of Memphis but was last registered in New Mexico in 2001. The old man I bought it from had purchased it a few years back from someone in New Mexico but its just sat in a field. It had since become a home for rodents. The original 170ci engine is in it however the carb was off and the plugs were missing. Considering the dead mice and droppings all over inside the van who knows whats inside the engine? I already have a running 200ci to drop in it so its not an issue. There is some minor rot.. Typical back corners will need to be replaced along with a small bottom section of the drivers side rocker panel. After pulling out the front factory floor mat I uncovered some rot in the floor pans. I will need to cut them out and weld in new ones. The underside actually looks to be in great condition with the factory undercoat still on in some areas. Otherwise there is only light surface rust. Even with its issues the deal was too good to pass up, especially for a DCW.
I think the weathered "patina" look is pretty cool, however a few friends think it looks hideous and needs to be paint. After fixing the few small rot issues and pulling the dents I was really considering dropping a clear coat and being done. Everyone will probably have a different opinion about keeping the "patina" look or not. I'm really excited to start on this one so I will do my best to post updates often! Below are a few pics thus far..
As the DCW was found out in Colorado
Pulled out of the weeds and ready to make the 1600mi trek to Pennsylvania
Before cleaning and disinfecting the inside
After a bit of cleanup and new rubber all around
