Need some help on switch removal can someone tell me how the ign ,light s,wiper, lighter switches are removed from dash on a 61econoline ?Thanks
switch removal
switch removal
Re: switch removal
IGN: ring unscrews from dash from around the key cylinder, switch pulls out from bottom.
Lights: there is a small button on the switch assembly... you pull the light knob, press the button, pull the light knob out. Then outer ring can be unscrewed from the dash and switch pulled out from bottom.
Lighter... back has a outer cylinder sandwiching a flange on the inner against the front of the dash. You unscrew the whole cylinder from the back side, lighter pops out the front.
Wiper: Allen key holds knob on to switch. Loosen allen key and remove knob. Undo nut from front and pull switch out the bottom.
Re: switch removal
Thanks very much Sasktrini
