    Hard time with this front end!
    canudigit
    canudigit
    Number of posts : 28
    Registration date : 2016-04-15
    Hard time with this front end! Empty Hard time with this front end!
    Post by canudigit Fri May 13, 2016 9:15 am
    Whats up guys! I'm here trying to get this van off the lift. Been fighting the front end. my DS spindle grease cap threads were toast. Found a replacement and its getting blasted as I type this. The king pin bores in the axle are jacked up. I went and found an axle, but the fella wont ship. I picked up an axle locally from an old timer... This thing was worthy of melting because the king pin bores were shot and and spindles had so much wear. Basically spent a day with my students cleaning this turd for nothing. I've gone ahead and searched for oversized king pins, but they dont make them for the 67 econoline axles. I figured I could use the 63 Over sized king pins and just trim them down to fit in the later spindle. I'll try and find a machine shop to size and fit everything or I'll just carefully run a reamer through the axle to get it to the proper oversize.
    In the mean time, we've been replacing all the bushings in the leaf springs and painting the shackles. We'v got a road worthy exhaust ready and I've found some nice ford Ranger Aluminum wheels to add to the mix. She's looking good. gotta get her back on the ground tho!
    Pics much later!
    Number of posts : 2086
    Hard time with this front end! Empty Re: Hard time with this front end!
    Post by Seth G Fri May 13, 2016 12:31 pm
    Hang in there, sounds like you're getting closer!
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 10:40 am
    Hard time with this front end! Img_6423
    Hard time with this front end! Img_6427
    Hard time with this front end! Img_6429
    Hard time with this front end! Img_6426
    Hard time with this front end! Img_6424
    Hard time with this front end! Img_6425
    Hard time with this front end! Img_6428
    Hard time with this front end! Img_6431
    Hard time with this front end! Img_6430
    Hard time with this front end! Img_6432
    Hard time with this front end! Img_6433
    Hard time with this front end! Img_6436
    Hard time with this front end! Img_6435
    Hard time with this front end! Img_6434
    Hard time with this front end! Img_6510
    Hard time with this front end! Img_6511
    Hard time with this front end! Img_6512
    Hard time with this front end! Img_6513
    Hard time with this front end! Img_6514
    Hard time with this front end! Img_6516
    Hard time with this front end! Img_6519
    Hard time with this front end! Img_6518
    Hard time with this front end! Img_6517
    Hard time with this front end! Img_6515
    Hard time with this front end! Img_6610
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 10:43 am
    Hard time with this front end! Img_6612
    Hard time with this front end! Img_6613
    Hard time with this front end! Img_6611
    Hard time with this front end! Img_6614
    Hard time with this front end! Img_6616
    Hard time with this front end! Img_6615
    Hard time with this front end! Img_6618
    Hard time with this front end! Img_6617
    Hard time with this front end! Img_6710
    Hard time with this front end! Img_6711
    Hard time with this front end! Img_6714
    Hard time with this front end! Img_6713
    Hard time with this front end! Img_6712
    Hard time with this front end! Img_6715
    Hard time with this front end! Img_6717
    Hard time with this front end! Img_6716
    Hard time with this front end! Img_6719
    Hard time with this front end! Img_6812
    Hard time with this front end! Img_6810
    Hard time with this front end! Img_6811
    Hard time with this front end! Img_6813
    Hard time with this front end! Img_6814
    Hard time with this front end! Img_6816
    Hard time with this front end! Img_6815
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 10:44 am
    Hard time with this front end! Img_6817
    Hard time with this front end! Img_6819
    Hard time with this front end! Img_6821
    Hard time with this front end! Img_6822
    Hard time with this front end! Img_6818
    Hard time with this front end! Img_6820
    Hard time with this front end! Img_6823
    Hard time with this front end! Img_6826
    Hard time with this front end! Img_6827
    Hard time with this front end! Img_6825
    Hard time with this front end! Img_6829
    Hard time with this front end! Img_6831
    Hard time with this front end! Img_6834
    Hard time with this front end! Img_6830
    Hard time with this front end! Img_6833
    Hard time with this front end! Img_6832
    Hard time with this front end! Img_6835
    Hard time with this front end! Img_6839
    Hard time with this front end! Img_6837
    Hard time with this front end! Img_6836
    Hard time with this front end! Img_6838
    Hard time with this front end! Img_6841
    Hard time with this front end! Img_6840
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 10:46 am
    Hard time with this front end! Img_6847
    Hard time with this front end! Img_6843
    Hard time with this front end! Img_6842
    Hard time with this front end! Img_6845
    Hard time with this front end! Img_6846
    Hard time with this front end! Img_6848
    Hard time with this front end! Img_6849
    Hard time with this front end! Img_6850
    Hard time with this front end! Img_6851
    Hard time with this front end! Img_6852
    Hard time with this front end! Img_6856
    Hard time with this front end! Img_6855
    Hard time with this front end! Img_6854
    Hard time with this front end! Img_6857
    Hard time with this front end! Img_6911
    Hard time with this front end! Img_6910
    Hard time with this front end! Img_6912
    Hard time with this front end! Img_6913
    Hard time with this front end! Img_6916
    Hard time with this front end! Img_6915
    Hard time with this front end! Img_6914
    Hard time with this front end! Img_6917
    Hard time with this front end! Img_6918
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 10:47 am
    Hard time with this front end! Img_6922
    Hard time with this front end! Img_6919
    canudigit
    canudigit
    Post by canudigit Thu May 26, 2016 11:03 am
    Ok.. so that was picture heavy.. hopefully you all have questions and comments. I did it my way. Axle is super tight now spindles and all.
    Number of posts : 1466
    Post by uante Thu May 26, 2016 11:20 am
    Purple Station wagon is pretty cool!
    Looks like you got a great place to work and lotsa tools!
    Post by Seth G Fri May 27, 2016 1:42 am
    Is it alright having the machined part of the spindle blasted? I'd have thought you'd want to mask that off.
    canudigit
    canudigit
    Post by canudigit Fri May 27, 2016 6:32 am
    Everything gets blasted. There was plenty of rust on it. The machined surfaces got hit very lightly. They aren't bearing surfaces nor are they hardened.
      Current date/time is Tue May 07, 2024 4:45 pm
