    leaf springs bushings
    Deluxxx
    Deluxxx
    Number of posts : 131
    Registration date : 2015-09-24
    leaf springs bushings - Page 2 Empty Re: leaf springs bushings
    Post by Deluxxx Mon Oct 26, 2015 12:37 pm
    gregb wrote:Hi donivan - ok just got springs back - i managed to get the 3 steel sleeves at 1 1/8 and the 1 at 1 5/8 on the passenger side front.
    as discussed i also sourced some of the poly urethane ones but as i said do you think i should replace the riubber bushings with polyurethane or order the rubber ones online ?
    - i manged to get a photo of my ride posted but i cant seem to post photos to a discussion yet.
    man i need help !! or a beer.
    I don't get why you can't, or wouldn't, replace all bushings to be the same size?
    gregb
    gregb
    Number of posts : 96
    Registration date : 2015-09-06
    Post by gregb Mon Oct 26, 2015 12:45 pm
    for whatever crazy reason some of the 65's the leaf spring on the passenger front the steel sleeve is 1 5/8 not the 1 1/8th.
    so i would have to actually change the spring. And you cant just change one spring you need to do both and there was nothing wrong with the springs itself.
    i was prettty confused by it ?
    cheers
    Deluxxx
    Deluxxx
    Post by Deluxxx Mon Oct 26, 2015 12:58 pm
    Are the spring eye diameters different, or is it just the inner sleeve?
    Deluxxx
    Deluxxx
    Post by Deluxxx Mon Oct 26, 2015 12:59 pm
    I have a '65 and I'm going to be doing what you've already done. My van's at the shop getting the rear end built, so I can't go under it to see for myself...
    gregb
    gregb
    Post by gregb Mon Oct 26, 2015 1:02 pm
    yes the eye of the spring is different. I though maybe it had one replaced but it appears by the info and Donivan that they do come with different sizes ??
    Deluxxx
    Deluxxx
    Post by Deluxxx Mon Oct 26, 2015 1:31 pm
    Everything about our bastard vans has to be difficult!
    gregb
    gregb
    Post by gregb Mon Oct 26, 2015 1:36 pm
    yea i hear on that one !! I cant beleive how hard it is to get parts ??
    though i did order the brakes for all the way arounf for 29.00 ??
    by the time the dust settled it was 1300.00 for new shocks, king pins ,flexible brake lines and all the leaf spring bushings. Plus my time ......oh thats free because i love dirt in my eyes and ears ...
    dont you love a hobby !! ahahahhaha
    Post by donivan65 Mon Oct 26, 2015 2:12 pm
    The hole in the spring is actually 1/2" bigger,,,,,,uses a bigger bushing,,,,,,,see both of them in my picture,,,,,,HOWEVER,,,,,I just got a box of 4.2126r  and I AM LIKING THEM,,,,,,,they are about 1/8" too wide, but that lets you custom fit them for a tight fit in your spring and frame,,,,So my OFFICIAL answer now is that these replace the 1 1/8" metal cartridges or my 2056 polyurethane bushings,,,,,,,the sleeves are for our 1st Gen 9/16" bolts,,,,,
    leaf springs bushings - Page 2 Dscn7118
    leaf springs bushings - Page 2 Dscn7119
    leaf springs bushings - Page 2 Dscn7120
    gregb
    gregb
    Post by gregb Mon Oct 26, 2015 2:32 pm
    thats what i got and mine were a little wider also
    i cut mine down the the 2.5 inches.
    i wish i didnt find the steel bushing as i would hav ejust done all the bushings in polyurethane.
    i even found the 1 5/8 inch in poly.
    learning on the fly !! yee haw eat your grandma !!
    cheers
    Deluxxx
    Deluxxx
    Post by Deluxxx Mon Oct 26, 2015 3:28 pm
    I guess that spooge drippage on the spring is what helped you get it slick enough to force it into the spring eye...?
    Post by donivan65 Mon Oct 26, 2015 4:00 pm
    no,,,,,them springs been sitting out for a long time,,,,,all rusted,,,,wire brushed the hole and sprayed it with WD 40,,,,,,,,dont want to mess them up just to take this picture for you guys,,,,,,bushings come a tube of lubricant,,,,looks like silicone,,,,,,bushings push in by hand,,,,
    gregb
    gregb
    leaf springs bushings - Page 2 Empty glove box hinge
    Post by gregb Thu Nov 05, 2015 12:44 pm
    Hey Donivan - my van cam with a wood glovebox door, i manged to buy the sportvan glove box on ebay for cheap, well it was cheap before shipping and exchange rate. Anyway i wonder if the hinge i have is period correct. Do you have a photo of your hinge so i can see if my is correct or if i need to go shopping. Or if anyone else could help.
    Also the glovebox door says sportvan on it. Is this from the factory.
    cheers
    Post by donivan65 Thu Nov 05, 2015 1:18 pm
    They stole those glove box doors off the Corvairs,,,,,,,,I seen fancy Chrome ones,,,,,,
    leaf springs bushings - Page 2 Dscn7210
    gregb
    gregb
    Post by gregb Fri Nov 06, 2015 9:08 am
    thanks Donivan - looks like i may get lucky and have the right hinge
    gregb
    gregb
    Post by gregb Mon Dec 28, 2015 2:32 pm
    Hi Donivan - happy holidays to ya !!
    Hope all is well .
    Well apparently I didn't get lucky with the hinge .
    The one I have is flat on the glove box door side so it sticks out 3/4 of an inch at bottom ??
    Maybe came from corvair or something, I bought that other one on eBay but it was shat !!
    I did get the outside ring chromed and put back together but now I need a proper hinge
    Since your the governor do you or anyone you know have an extra for sale ?
    I should have left the homemade wood one on there !lol
    I guess I am a gluten for punishment
    Anyway have a great holiday
    Cheers
    Post by donivan65 Mon Dec 28, 2015 4:11 pm
    a REAL hinge is about 12 3/4" long,,,,,,and sort of L shaped,,,,what do you got?
    ,,,,,the pictures dont seem to be showing up today,,,I dont see my 2 pictures here,,,,,
    leaf springs bushings - Page 2 Dscn7430
    leaf springs bushings - Page 2 Dscn7431
    gregb
    gregb
    Post by gregb Tue Dec 29, 2015 12:45 pm
    https://i.servimg.com/u/f68/19/34/46/72/work_031.jpg
    this is as far as i can get with posting a photo Donivan !!
    do you have a regular email i can send the photos to ?
    i do have the wrong hinge though .......
    gregb
    gregb
    Post by gregb Tue Dec 29, 2015 12:47 pm
    hey it will let you open that link !! WTF ? i have had 2 of my girls trying to get that photo sharing to work ??
    i will send a few more
    gregb
    gregb
    Post by gregb Tue Dec 29, 2015 12:50 pm
    https://i.servimg.com/u/f68/19/34/46/72/work_032.jpg
    here are a few more donivan - not sure if it will work
    Last edited by gregb on Tue Dec 29, 2015 12:53 pm; edited 1 time in total (Reason for editing : didnt work)
    gregb
    gregb
    Post by gregb Tue Dec 29, 2015 12:52 pm
    Post by donivan65 Tue Dec 29, 2015 9:01 pm
    ok,,,,,,,the site picture posting was not working yesterday    but I see your links,,,,,,your hinge is different,,,,,,maybe its a  Corvair,,,,I dont think you can bend it to fit a Chevy van too easily,,,,,,,
    leaf springs bushings - Page 2 Work_010
    leaf springs bushings - Page 2 Dscn7434
    leaf springs bushings - Page 2 Dscn7435
    gregb
    gregb
    Post by gregb Wed Dec 30, 2015 9:09 am
    my latch is wrong also ??
    Number of posts : 1279
    Post by Space Truckin Wed Dec 30, 2015 9:36 am
    How did this go from leaf spring bushings to glove box springs/ latch lol
    Post by donivan65 Wed Dec 30, 2015 10:02 am
    ,,,,,,if its broke,,,,,we are going to fix it,,,,,,,,,,,,,,,,,,
    Post by donivan65 Wed Dec 30, 2015 11:49 am
    now if I had a Corvair hinge on my Chevy van glovebox door,,,,,,I would take the hinge off,,,,knock the pin out,,,,,,screw the door half to a piece of wood, then either with vice grips or put a 1/4 thinner piece of wood under it and bend a step into it,,,,,maybe smash it down with a chisel,,,thats called a dogleg,,,,,,it dont have to be perfect,,,,just lower so it moves the door closer to the dash when you close it,,,,,,,
    leaf springs bushings - Page 2 Dscn7438
    leaf springs bushings - Page 2 Dscn7439
    leaf springs bushings - Page 2 Dscn7440
      Current date/time is Fri Apr 26, 2024 12:35 pm
