    Rewiring - Light Switch Schematic Headaches
    Udo
    Udo
    Number of posts : 247
    Registration date : 2014-07-07
    Rewiring - Light Switch Schematic Headaches Empty Rewiring - Light Switch Schematic Headaches
    Post by Udo Tue Sep 08, 2015 12:48 pm
    Does anyone happen to have the wiring diagram for the c4dz-11654-a?
    I noticed it was the same as my original C4DB and CG has a photo of the newer one with a schematic on it but I cannot read two of the pins
    Rewiring - Light Switch Schematic Headaches C4dz-110
    So...from upper left across to right and back to lower left across.
    P=Park Lights?
    B2=Battery +
    D=Is that a D? Interior/Interior Power +?  No
    B1=Battery +
    H or R???=Ext Lamps or Headlight Dimmer?
    H or N=I cannot read that middle one...H I would say for headlights?
    I=Instrument Dimmer
    Cheers in advance!!!
    Carl
    Number of posts : 143
    Rewiring - Light Switch Schematic Headaches Empty Light switch wiring diagram
    Post by Carl Wed Sep 09, 2015 11:32 pm
    Udo
    Udo
    Rewiring - Light Switch Schematic Headaches Empty Re: Rewiring - Light Switch Schematic Headaches
    Post by Udo Thu Sep 10, 2015 8:04 am
    Cheers but that diagram doesn't specify the light switch pins.
    I managed to figure it out however and just managed to map out the turn signal switch as well, that was a bit of a challenge lol.
    To help others out here are the specs:
    B1=Battery + that connects and powers H for headlights (the pin at the 7 o'clock position to D)
    R= Running or Exterior Lights
    I= Instrument lighting (dimming)
    P= Parking Lights
    B2= Battery + that powers the Running Lights (R)
    H= Headlights
    D= Dome/Interior Lighting
    Cheers
      Current date/time is Fri Apr 26, 2024 6:46 pm
