    Neutral switch-/back up light switch??= where it mounts?
    Neutral switch-/back up light switch??= where  it mounts? Empty Neutral switch-/back up light switch??= where it mounts?
    Post by Twinpilot001 Thu Sep 01, 2011 12:47 pm
    [i]here are some pics of my neutral (?/ back up?? light switch) switch= this if on a factory 1967 V-8 (not modified) and powerglide trans. My question is this= the bracket is different than a inline 6 cyl motor/trans mount(same automatic) note bracket in pics. It will not fit where the 6cyl moptor switch does=on the powerglide / engine bellhousing area-. due to extra lenght arm of bracket. There are also 2 holes in floor just above this switch- would it mount there ?? The switch bracket has a bolt in it & bracket is threaded for that bolt. Anyone have this same as origional from factory on a gen 2 chev sportvan?? Thanx
    Neutral switch-/back up light switch??= where  it mounts? Dscn2710
    Neutral switch-/back up light switch??= where  it mounts? Dscn2711
    Neutral switch-/back up light switch??= where  it mounts? Empty Re: Neutral switch-/back up light switch??= where it mounts?
    Post by donivan65 Thu Sep 01, 2011 3:10 pm
    It goes on the trans bolt or in that hole,,,,
    Neutral switch-/back up light switch??= where  it mounts? Vanish17
    Neutral switch-/back up light switch??= where  it mounts? Empty Inderstand now-Thanx
    Post by Twinpilot001 Thu Sep 01, 2011 5:01 pm
    yes I do see now as looks like it not only bolts to the trans yet also to the flywheel cover area -Thanx a bunch,matt[i]
      Current date/time is Wed May 08, 2024 3:44 pm
