    neutral switch?/ Question
    neutral switch?/ Question Empty neutral switch?/ Question
    Post by Twinpilot001 Thu Aug 09, 2012 1:05 pm
    Im curious - does a 1966 g10 van (3 speed on column) have a neutral start switch? if so where is it located?? trans or clutch linkage - ive got someone asking me.
    neutral switch?/ Question Empty Re: neutral switch?/ Question
    Post by donivan65 Thu Aug 09, 2012 5:13 pm
    A manual trans does not have a neutral start switch,,,,they did put them on the clutch pedal like around the 1980's,,,,,,the automatics have them mounted on the bellhousing with a rod connecting it to the lever coming out of the transmission,,,,,probably in 1966, that switch also contained Back up light contacts in it,,,,,,
    Post by Twinpilot001 Thu Aug 09, 2012 6:28 pm
    [iThanx doni- as i thought ill inform the friend -hes having starter problems -wiring related
    Post by donivan65 Thu Aug 09, 2012 11:57 pm
    After the juice has to go from the starter solenoid,,,,through the wiring,,,,through the ignition switch,,,back through the wiring to the solenoid, there ain't much left to energize the starter, especially if the engine is hot. so I add a Ford relay nearby, so that the ignition switch just energizes the Ford Relay and it does all the heavy lifting,,,,,,
    neutral switch?/ Question Ford_r10
    Post by donivan65 Fri Aug 10, 2012 12:03 am
    neutral switch?/ Question Nodoor91
    Post by Twinpilot001 Fri Aug 10, 2012 6:18 am
    nice -thanx all- this vehicle is a 66 chev & i believe the fuseable link is bad- have power on key switch "S" term & still nothing @ starter solenoid. kusl have to find the area in wiring & my bones dont bend much anymore- under & over all -OH I Ache >
    Post by donivan65 Fri Aug 10, 2012 9:13 am
    There should not be any fusible links on a 66,,,,,,but #1 suspect in my book is the connector in the doghouse right next to the carburetor above the alternator,,,,wiggle that,,,,,,,
    Post by Twinpilot001 Fri Aug 10, 2012 9:20 am
    Thanx ill look cheers
      Current date/time is Fri May 17, 2024 4:23 am
