ricecube384
    Name That Part
    ricecube384
    ricecube384
    Number of posts : 11
    Registration date : 2014-08-01
    Name That Part Empty Name That Part
    Post by ricecube384 Fri Aug 15, 2014 1:06 pm
    Hello!
    I've have a little play in the shifter specifically getting into 1st and Reverse and sometimes it can stick in gear when parked. The guy i bought the van from thinks the culprit is the part in the pic hose clamped to the steering column. Wish i took a pic of the other side, but it is missing a chunk and possibly not allowing the shifter to align properly. I want to order the part, but dont know what the thing is called. Any help and or advice would be greatly appreciated!
    Name That Part Photo212
    Name That Part Empty Re: Name That Part
    Post by donivan65 Fri Aug 15, 2014 7:34 pm
    Upper Mast Jacket Support.....
    Post by donivan65 Fri Aug 15, 2014 7:46 pm
    Name That Part Dscn5221
    ricecube384
    ricecube384
    Post by ricecube384 Sat Aug 16, 2014 9:11 am
    THANKS Donivan!
    Post by donivan65 Sat Aug 16, 2014 1:23 pm
    Other stuff going wrong causes that part to break,,,,,,,,,make sure the levers are adjusted and the bushings on the both levers and on the transmission are good,,,,,,,,that shift lever needs to come out 1st if you want to take that part off.....
    Name That Part Repair46
    ricecube384
    ricecube384
    Post by ricecube384 Thu Jun 18, 2015 7:45 pm
    Resurrecting an old post here. Anyone know where I can get a upper mast support? Turns out that hose clamp was holding the thing together when trying to resolve the shifting issues.
    Name That Part Image11
    Number of posts : 1412
    Post by Vantasia Fri Jun 19, 2015 4:13 am
    As far I know, not reproduced, have to keep asking around for a parts van donor, many have converted to auto trannies and save/sell the left over shifter parts, put out a plea here and at VCVC, someone will have one, I have seen this part requested and fufilled before by others....
    Post by Digz Fri Jun 19, 2015 4:58 am
    Should be able to hook you up. I'll check the stash.
    ricecube384
    ricecube384
    Post by ricecube384 Fri Jun 19, 2015 10:02 am
    Thank you for the replies and @donivan, Please keep me posted! The sooner i can get this installed, the sooner i can get this thing on the road. pirat
    Post by Digz Fri Jun 19, 2015 12:58 pm
    Got ya covered. Get pics up when I get back to a PC.
    Name That Part Shift_10
    Name That Part Shift_11
    Name That Part Shift_12
    10$ includes postage.
    ricecube384
    ricecube384
    Post by ricecube384 Fri Jun 19, 2015 7:30 pm
    Heck Yea! Let's do this!
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Tue Jun 30, 2015 6:37 am
    Sorry I haven't seen one of those around. Should be some as so many convert to automatics. Heard about them braking so I put a garden hose gasket up in the top. Makes it less clunky and I hope less likely to break. Also, first, I rebuilt all the linkages with factory rubber bushings and plenty of white lithium grease. Shifts so nice I now prefer Three on the Tree (Where it Should Be) over floor shifters. Kind of amazing really when one considers the linkages are 5 or 6 feet long. So, in other words, I'd fix up the rest of the linkage assembly while trying to find that part. Good luck!
    Magic Potion
    Magic Potion
    Number of posts : 148
    Registration date : 2015-03-13
    Post by Magic Potion Tue Jun 30, 2015 7:16 am
    Mine has a hose clamp holding the mast support together but it is an automatic. My question is are the first and second gen mast supports interchangeable?
    Magic Potion
    Magic Potion
    Post by Magic Potion Wed Jul 01, 2015 2:49 pm
    I guess I will just go ahead and buy it. If it doesn't work I'm sure someone will need it eventually.
    Magic Potion
    Magic Potion
    Post by Magic Potion Fri Jul 03, 2015 3:13 pm
    So apparently a 2nd Gen doesn't have the same upper mast support.
    Magic Potion
    Magic Potion
    Post by Magic Potion Sun Aug 02, 2015 5:19 pm
    Is the upper mast support made with pot metal? And if it is does it have zinc in it?
    Post by Digz Sun Aug 02, 2015 8:32 pm
    I will check and see if I have another one around, not sure but quite possible.
    Magic Potion
    Magic Potion
    Post by Magic Potion Sun Aug 02, 2015 10:06 pm
    I have a friend with some skill in that department just need to know what he is dealing with.
      Current date/time is Fri Apr 26, 2024 10:33 am
