    Centering the engine
    AzDon
    AzDon
    Number of posts : 742
    Centering the engine Empty Centering the engine
    Post by AzDon Fri Jun 26, 2015 1:00 pm
    I'm planning to move my engine back 18 inches and I'm wondering if there is a good reason not to "center" the engine, since seating interference would no longer be an issue.
    A little measuring tells me that the frame rails are not offset, but that the stock engine cradle is.....I can't see a difference in leaf springs, side-to-side, and wonder if the right side engine bias was meant to be compensated by the weight of the driver (?)
    Centering the engine Empty Re: Centering the engine
    Post by Big W Fri Jun 26, 2015 2:10 pm
    I believe the motor is off set to match up to the off set with the rear dif.
    AzDon
    AzDon
    Post by AzDon Fri Jun 26, 2015 5:37 pm
    I had a 69 Ford van years ago that definitely had the pumpkin offset to the right to match engine placement.....I don't think Chevy and GMC have offset pumpkins (guess I'll need to measure)
    VCVCSmiley
    VCVCSmiley
    Number of posts : 73
    Post by VCVCSmiley Mon Jul 27, 2015 7:52 am
    The early Chevy vans' rear is offset. Unless you are swapping the rear in from another application, you'll need to maintain that engine offset.
    AzDon
    AzDon
    Post by AzDon Sat Aug 01, 2015 8:10 pm
    I ran a tape measure on it and the driveshaft yoke is exactly centered between the left and right leaf spring and the diff appears to be stock......
    I HAVE seen GM differentials on center where one axle is longer because of the extra distance into the carrier on the side that holds the ring gear (I think they are all this way, but I'm not sure) The 12 bolt in my 68 Suburban is like this....
    Post by Digz Sun Aug 02, 2015 12:36 pm
    If it is a van rear axle assembly the axles are the same length. It is the pinion that is offset in the housing. Some pics would be nice?
    AzDon
    AzDon
    Post by AzDon Sun Aug 23, 2015 6:25 pm
    Leaf spring to the yoke dust collar is 21 5/8 inches on both sides and both the front pulley and trans hanger bolt appear to be one inch right of center (2" difference in measurement per side is corrected by taking away an inch on one side and adding it to the other)
    I'm not sure that a 1" offset is worth the effort to correct or even if it results in a measurable side-to-side weight bias....The u-joints probably actually like the slight phasing.......
      Current date/time is Mon May 06, 2024 9:38 pm
