    Overdrive trans and wheel pattern questions
    Overdrive trans and wheel pattern questions Empty Overdrive trans and wheel pattern questions
    Post by Guest Sun Apr 12, 2009 6:06 pm
    Will a 518 Overdrive trans fit in a V8 A van easily? Has anyone does it?
    also..
    what is the wheel bolt pattern? 5 on 4.5? 5 on 5?
    Overdrive trans and wheel pattern questions Empty Re: Overdrive trans and wheel pattern questions
    Post by Guest Mon Apr 13, 2009 3:48 am
    5 on 4.5 through 1984.
    It would be best to swap the A518 into an A108 rather than a shorty. The A518 is longer than a regular A727 and alot longer than a stock A100 A727. NOt saying that it can't be done, but you won't have much of a driveshaft at all.
      Current date/time is Sun Apr 28, 2024 12:29 am
