Hi. I had some problems with the fuel pump. Thanks to all for the helpful inputs, I was able to fix it.
I'm having trouble running the car. The engine, 318, would cranck, but won't turnover.
I've replaced all the sparks, checked the distributer gets sparks and the spark connections seem fine. It has been sitting for almost a year now. I tried spraying the carbs with some fuel spray. Still won't turn over. I believe the carbs gets fuel and the fuel lines are OK. Any inputs to help get the van to run?
Below I'm attaching a pic of the old sparks and a video of the carbs squirting fuel when I push the throttle, if they may help diagnose the situation better.
old sparks: https://i.imgur.com/91yyb5C.jpg , https://i.imgur.com/elX98OW.jpg
Carbs vid: ...uploading ATM. Will post soon.
