    Where to find bushings for Z bar linkage and what oil pan to use in my 300 swap?
    J_Money
    J_Money
    Number of posts : 2
    Registration date : 2014-12-11
    Where to find bushings for Z bar linkage and what oil pan to use in my 300 swap? Empty Where to find bushings for Z bar linkage and what oil pan to use in my 300 swap?
    Post by J_Money Wed Jan 07, 2015 3:43 pm
    Two totally different questions, but when I pulled my engine and transmission out I realized the bushings in the Z equalizer bar are worn through. I can't seem to find a replacement locally. I imagine it would be the same as an f100 from the same era?
    Also I just pulled the 200 out of my van, I have the correct cross member for the swap but I'm not sure about the oil pan. I have the pan out of a 78 f150. Will this clear or will I need to locate a factory pan from a 240?
    Thanks
    Vancy65
    Vancy65
    Number of posts : 47
    Registration date : 2014-03-10
    Where to find bushings for Z bar linkage and what oil pan to use in my 300 swap? Empty Re: Where to find bushings for Z bar linkage and what oil pan to use in my 300 swap?
    Post by Vancy65 Wed Jan 07, 2015 4:04 pm
    Hi J_Money,
    http://cgfordparts.com sells the bushings and many other good parts and I think you have to use a special Econoline 240 oil pan, but I'm not 100percent sure with that.
      Current date/time is Wed May 08, 2024 4:23 am
