65 Handy Info
65 Handy Info
What engine did the a 65 Handy van come with? I will be picking this one up in the next couple of weeks, havent worked all the details out yet, but will do a fly and drive for it, its in Tuson.
Re: 65 Handy Info
I would say 153 4 cylinder and 230 6 cylinder,,,,,
It should be on the plate below the lower drivers side hinge.
Re: 65 Handy Info
But is it the original????? If you are heading West on I-8 and then up north on I-15,,,,,,chances are pretty good you would meet up with me and my van,,,,,,,,,,or we can find your bones in the Desert some day,,,,,,,
Re: 65 Handy Info
A standard 1965 G1001 Handi-Van had either a 153 or a 194. The 230 was an option. But like Donivan said, who knows if its the original.
Re: 65 Handy Info
donivan65 wrote:But is it the original????? If you are heading West on I-8 and then up north on I-15,,,,,,chances are pretty good you would meet up with me and my van,,,,,,,,,,or we can find your bones in the Desert some day,,,,,,,
I will be coming back on the 10! Might need your experience for a 4x convertion though, havent decided yet. You wouldnt know the curb weight on a converted panel would ya?
Eric64- Number of posts : 18
Registration date : 2009-03-24
Re: 65 Handy Info
I've seen this van around town for several years, I believe it's on the east side of town now, if you get lost or need anything drop me a line. 520-850-5829 Eric
Re: 65 Handy Info
I got a 230 -6 in my 65 handy...it is all there... Engine and trans...dont run yet, but the trans works and clutch still works...
Re: 65 Handy Info
A 4cyl was available in these??? Holy crap...I bet you'd even get passed by a VW bus going up a hill! LOL!
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: 65 Handy Info
1963 GMC and 1964-5 G10's came with 153 4 banger or the
optional 194 HT 6 banger. The 230 wasn't offered as an factory option until late 1966.
Re: 65 Handy Info
Re: 65 Handy Info
Well lookie there. Guess this sets it straight. I was told wrong on the engine sizes.... I'm going to save this pic for the records.... Thanks Don.
Re: 65 Handy Info
Re: 65 Handy Info
Sweet, Thank you... That's why your the "Gov'ner"!!!
Re: 65 Handy Info
Yeah right,,,,,,,like a site even needs a Governor,,,,,,,,,,
Re: 65 Handy Info
I dont know about this site needing a governor, but Don, this site sure as hell needs you!!!!
RipVanArkie- Moderator
- Number of posts : 987
- Post n°19
Re: 65 Handy Info
SIX-FO' wrote:I dont know about this site needing a governor, but Don, this site sure as hell needs you!!!!
Ditto,
Rip
- Post n°20
Re: 65 Handy Info
How do I tell what engine is in it? Where would I find the size code on the block?
- Post n°21
Re: 65 Handy Info
donivan65 wrote:Yeah right,,,,,,,like a site even needs a Governor,,,,,,,,,,
Yes Don your right, but your knowledge and contribution to the member’s of this site does warrant a “Prestigious Title” of some sort…. Just glad you’re here and can’t begin to tell you how much you’ve helped me along the way but I can say it has saved me “A LOT” of frustration, so thank you…
- Post n°22
Re: 65 Handy Info
The codes are right by where the bolt that holds the distributor is. But I don't have too much faith in that system. There are also casting numbers by the dipstick but the most reliable way is when the head is off,,,,,,measure the bore and stroke,,,,,the 194, 230 and 250 are all different and easy to tell apart,,,,,and the 153 is a little 4 cylinder,,,,,,the 292 is a real tall engine and its right motor mount is in the wrong place,,,,
- Post n°23
Re: 65 Handy Info
Kowboy,
When you find the numbers, check this list to see if you can find yours...
Dan
https://vintage-vans.forumotion.com/member-s-showcase-f2/gm-l6-enginne-block-casting-numbers-t4505.htm#18200
Dan
