Does anyone know if a 66 Truck radiator is the same as the G10 Van Radiator? I'm having overheating issues and I'm wanting to go to an aluminum radiator but not having a lot of luck finding one that says it will fit my van. But I do see quite a few that fits the 66 truck.
66 G10 Radiator
Rockandrollerman- Number of posts : 24
Registration date : 2014-05-18
66 G10 Radiator
jazzcat- Number of posts : 35
Registration date : 2014-05-03
Re: 66 G10 Radiator
There's no direct replacement, but there are plenty of solutions that forum members have documented. Including mine, where I relocated the filler neck..... see the search below.
Chris
https://vintage-vans.forumotion.com/search?search_keywords=radiator&sid=&q=&domains=vintage-vans.forumotion.com&sitesearch=vintage-vans.forumotion.com&client=&forid=1&channel=3119321536&ie=iso-8859-1&oe=iso-8859-1&hl=en&cof=GALT%3A%23f9ffd9%3BGL%3A1%3BDIV%3A%23222222%3BVLC%3A%23d2e0ac%3BAH%3Acenter%3BBGC%3A%23141414%3BLBGC%3A%23222222%3BALC%3A%23dce8a5%3BLC%3A%23f9ffd9%3BT%3A%23e3f8fa%3BGFNT%3A%23f9ffd9%3BGIMP%3A%23f9ffd9%3BFORID%3A11&search_terms=any&search_author=&search_where=f4&search_time=0&show_results=topics&sort_by=0&sort_dir=DESC&google=
Chris
Re: 66 G10 Radiator
Wwildman- Number of posts : 12
Registration date : 2014-07-01
Re: 66 G10 Radiator
here is a direct swap for cheap
http://www.ebay.com/itm/230828903261?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Re: 66 G10 Radiator
Thanks for the reply's.
Not much of an aluminum welding kind of guy lol in fact not a good welder at all.
How does the angle iron attach to the sides...weld, rivet, or bolt on?
The Mustang one will fit with no alterations?
Re: 66 G10 Radiator
You got a core support that the radiator bolts to,,,,,unless you got a fancy SportVan,,,,,you need a 1 1/2" hose connector in the upper left hand corner,,,a 1 3/4" one in the lower right hand corner,,,,,all the radiators have mounting holes to mount them to a core support,,,,,,you bolt it in,,,,,,you might have to drill holes or use a piece of angle iron to get the radiator mount to the core support,,,,,,anything better than tie wraps will get the job done,,,,,just get one that fits in the doghouse......
Re: 66 G10 Radiator
now,,,,,,,if you have a SportVan,,,,,,the radiator bolts right to the doghouse on the passenger side,,,,,,you will need some angle iron or L brackets ,,,,,,a normal van has the bolts going front to back,,,,a SportVan has them side to side.....
Re: 66 G10 Radiator
Re: 66 G10 Radiator
Yup mine is a Sportvan custom. So they are mounted on the side. Thanks
Re: 66 G10 Radiator
Re: 66 G10 Radiator
I will be removing it hopefully in the next few days and I will take pictures and post them so we can find out if it is original thanks, for all the help.
