new radiator
new radiator
anyone know were i can find a new radiator? thanks for any help,
- Number of posts : 8731
Re: new radiator
call these guys. tell them what you have. and what you want . 2 core, 3 core, 4 core, . great prices minor altering made in the USA. http://www.fsrradiator.com/
Re: new radiator
thanks dix, you always help me out,, i couldnt find one anywere,
Re: new radiator
maybe next year you will be at butler van in.
Re: new radiator
forsure i will make it this time, should have everything done on the van by then
blackace- Number of posts : 450
Re: new radiator
Dodge Man, what part of Ohio are you in? I am up in Van Wert, so if you are ever up in this neck of the woods, look me up for a cold one and good stories about the oldies
Re: new radiator
you do the same blackace, i'm in toronto oh. along the ohio river just north of steubenville,
Re: new radiator
dodge man you must be about 15 min. from this years van nats in ohio. 2010 had i think 680 vans..
Stoopid john- Number of posts : 265
Re: new radiator
Re: new radiator
i'm about 45 miles from pittsburgh, were was the nats.?dix wrote:dodge man you must be about 15 min. from this years van nats in ohio. 2010 had i think 680 vans..
Re: new radiator
thanks for the pictures john, the v8 van has the lower hose on the other side or i could use the same one you did, i wonder if summit has one like i need?
Re: new radiator
The Nats look to be in Old Washington, which seems to be about 1hr back towards Columbus. That is about 3 to 3 1/2 hrs for me.
Re: new radiator
i'm across the river from west virginia pan handle, columbus is about 2 1/2 hour drive for me,
Re: new radiator
Dodge nan the nats are near zannsville. i thought that was close to you just off I 70 i think mile marker 86.
Re: new radiator
about an hour and a half away, will they hold the nationals there again this year? i hope to have all the kinks out of the van by spring and do some traveling,
Re: new radiator
yes that is were the nats will be.
Re: new radiator
Re: new radiator
man i got to make it there this year,
- Post n°19
Re: new radiator
were at in zannsville at there fairgrounds? and when is it
- Post n°20
Re: new radiator
when i call up four seasons radiator will i need all the measurements or do they have a part # for the one i need?
- Post n°21
Re: new radiator
let me see what i can find. the one i used is built for a tug. A tug is used at the airports to move airplanes around. it has two inlets up top and two out lets on the bottom . and would come with two plugs for the two ports that you don't use the one in the photo is what it looks like. you will have to cut a new hole at the rad support for the top hose and trim town 1 side to fit it in . just stack the old one on top of the new one. http://www.fsrradiator.com/ or click on tug radiator
- Post n°22
Re: new radiator
I WAS THINKING ABOUT TAKING MY RAD. TO A RAD. SHOP TO SEE IF THEY COULD RECORE MINE, IT MIGHT BE THE BEST THING TO DO, AND I KNOW IT WOULD FIT, I DONT THINK I WOULD LIKE A 4 NECK RAD. THAT YOU HAVE TO PLUG OFF 2, MORE CHANCES OF LEAKS.
Hey Dix-what engines are in those tugs/
seems if memory is still good for me ???? They were origionally some old ford Flathead types that used dual water pumps?? were down in the motor mount areas . Also some used some contential engines also =same ways i believe. That 2 inlets & 2 outlets -jogged my memory a bit there on that.
- Post n°24
Re: new radiator
There is also an early Van radiator thats on ebal also - says its a 4 core fits a 64-66 i believe.
- Post n°25
