thats a great price for a 4 core, everything is backwords from mine,
new radiator
- Post n°26
Re: new radiator
- Number of posts : 8732
- Post n°27
Re: new radiator
i'm not sure obout the tug motor got the info from the man who runs the yahoo a100 site out of detroit he worked a sprint airlines till he was laid off. the rad has been in my van for 3 or 4 years . and no leaks. tell fsr your intersted in the tug type rad with only 2 ports 1 up and 1 down. i had to think about it . the factory rad has 1 flange on each side these have a c channel so i cut off the back side of the c off. but they can make it how ever you would like.
- Post n°28
Re: new radiator
this is the rad i used . look closly at the c channel on the sides i trimed off the flange on both sides closest on the engine and used the flanges closest to the grill to mount the rad.155360-4 the last number (4) is 4 ports you can get (2) ports. either way the ports do not line up with the existing rad support hole. the same part number with out the (4) is a (2) port rad and the flange looks to be on the grill side of the rad. this is why i suggested to call them if you pull the rad and make a drawing with measurments they can make it happen. http://www.fsrradiator.com/
- Post n°29
Re: new radiator
the nats is exit 186 on rt 70. http://www.van-nationals.com/p/how-to-get-here.html
- Post n°30
Re: new radiator
i'll call four seasons before i have mine recored, if i can make them a template of mine to be made of alumium that would be great,i'de like a 3 core, that should keep it cool, and thanks for the directions to the nationals,
- Post n°31
Re: new radiator
155369 belt load looks like it would have the correct location for the ports, as soon as i'm ready i'll call them, thanks again dix,
- Post n°32
Re: new radiator
most likley to wide and not tall enough. that is the problem matching up the existing rad , most rads are wider than tall but these earlies are so confinded in the dog house they built special rads for them.
- Post n°33
Re: new radiator
i'll call them and see if they will make me one with my template, to my exact specs, i could send them pictures of mine also,
- Post n°34
Radiator
I took mine to a local radiator shop here and they recored it with a three row for me. It was about $400. but I knew it would fit, and came with a three year warranty. My 108 has a 318 in it like yours.
- Post n°35
Re: new radiator
thanks tom, thats more than likely what i'll do
