Stoopid john
    My radiator fix
    Stoopid john
    Stoopid john
    Number of posts : 265
    My radiator fix Empty My radiator fix
    Post by Stoopid john Sat Jul 16, 2011 8:42 pm
    So, i'm driving my van 50 miles a day in the florida heat. I knew it was only a matter of time before i needed a radiator, just not so soon. My top tank split and started to leak. I don't know of any radiator repair shops around my that i would trust.
    I found a griffin aluminum radiator that is made for a 32 ford streetrod. Almost the same size, and the only real difference was the the top hose is dead center, instead of off to the right. The price was right too $253 to my door.
    I can give you part numbers of very thing i used, i even picked up molded hoses that fit.
    Here are the pics i have
    My radiator fix Normal_100_1589
    My radiator fix Normal_100_1588
    My radiator fix Normal_100_1591
    My radiator fix Normal_100_1597
    My radiator fix Normal_100_1599
    My radiator fix Empty Re: My radiator fix
    Post by Twinpilot001 Sat Jul 16, 2011 8:46 pm
    how many cores = like 3-4 ?? can u fix ur orig one = only takes some solder & hand propane torch & flux to fix it ??
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Jul 16, 2011 8:54 pm
    To start i set the shroud on to see what i needed to cut. The next thing was the i went to the hardware store and bought some flat aluminum stock to make everything bolt up. I took my time and trimmed everything up.
    My radiator fix Normal_100_1607
    My radiator fix Normal_100_1608
    My radiator fix Normal_100_1609
    My radiator fix Normal_100_1610
    My radiator fix Normal_100_1611
    My radiator fix Normal_100_1612
    My radiator fix Normal_100_1613
    My radiator fix Normal_100_1615
    I'll let you know how it does monday night, before it would run about 3/4 on the factory temp gauge. It would ping alittle close to home so i know it was getting hot.
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Jul 16, 2011 9:00 pm
    The one that was in it was a 2 row and every row i can see is plugged. The new one is also a 2 row but the tubs are twice as big. Most all aluminum radiators are only 2 row.
    Number of posts : 745
    Post by kiwimopar Sat Jul 16, 2011 9:16 pm
    Awesome job Cool
    Stoopid john
    Stoopid john
    Post by Stoopid john Sat Jul 16, 2011 9:26 pm
    I also put a new water pump on it, it was just to easy not to.
    My radiator fix Normal_100_1604
    Post by kiwimopar Sat Jul 16, 2011 10:42 pm
    I'm seeing the advantages of having a van over a pickup now Very Happy
    Post by Twinpilot001 Sun Jul 17, 2011 4:34 am
    Mods lookinj Great!!
    Number of posts : 917
    Post by wylee Sun Jul 17, 2011 5:40 am
    great job ....................................................
    mrfoochie
    Number of posts : 24
    Registration date : 2011-01-10
    Post by mrfoochie Sun Jul 24, 2011 5:41 pm
    part numbers? do they have one with a trans cooler?
    Stoopid john
    Stoopid john
    Post by Stoopid john Sun Jul 24, 2011 6:06 pm
    No coolers, summit's # is GRI-1-202DF-AXX
    The hoses are from autozone
    60794 upper
    71017 lower
    Number of posts : 7900
    Post by DanTheVanMan Mon Jul 25, 2011 4:59 am
    Looks great John!!!! cheers
    My radiator fix Qr_cod10
      Current date/time is Sun May 19, 2024 6:05 am
