Hello again,
I've been doing a bit more research into this, I haven't had the time to touch this van until recently but had some time last night.
I found out that the 144ci, 170ci and 200ci are less powerful than previously thought. Back in the day they had very hyped up horsepower and torque figures. For example a 200ci may make 70hp and 124 torque at the dyno, a far cry from the 120hp they claim. Another example of HP rating changes is with the 250ci, it was originally advertised as having 155hp, but when they changed the calculations for HP it dropped to a whopping 88hp. Having any 4 banger built past the 80's is quite adequate to boost the performance of this vehicle.
I've found that the Lima 2.3 > 2.5l are ideal for this conversion. They're quite narrow engines, very cheap, with a huge aftermarket for them. They still build this engine as an industrial engine called the LRG425. Another reason this engine is ideal is that this engine has problems reaching the proper operating temperature, this motor actually runs cool, perfect for a small doghouse. The industrial engine is only slightly wider than 20in at (21in) due to the alternator which can be relocated (the ranger version has it located in front of the intake), it's also worth noting that the alternator is decently low so any mod to the doghouse maybe under the lid line (easier to fab).
I'm attaching pics of one going into an econoline pickup from a user called "motorjunkie", didn't find a completed one though.
He claims his Econoline gets 20mpg with this swap. Other people who've worked with these engines for falcons claim that the wiring was made very simple too.
