Ryan
+4
8 posters
Shocks for a 64
Shocks for a 64
I'm looking to get new shocks all around for my 64' GMC. I wanted to know what you guys are using or if you have any suggestions on what I should use. My van is still rollin' on those twisty original shocks so I gotta get some new ones. Thanks,
Ryan
Ryan
Re: Shocks for a 64
Have you tried Napa???
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: Shocks for a 64
AutoZone has them too.
Re: Shocks for a 64
they should work, but I would try your local auto parts first and save on the shipping
Vanish- Admin
- Number of posts : 5155
Re: Shocks for a 64
Hey I think thise are for P Series !!!!!!!! ???????
,,,Vanish,,,
MCMLXV
Re: Shocks for a 64
Ya, I think your right vanish. I was looking at these because 75 bucks a pair seems cheap for coilovers. But thats why I ask you guys, you know everything.
Re: Shocks for a 64
I have been thinking about replacing my shocks, everytime I go over a bump. Post how well these work.
Thanks.
Dave
Thanks.
Dave
Re: Shocks for a 64
All 4 shocks are not the same,,,,, the front shocks are like 6 inches longer than the rear,,,,,,,and the Autozone website shows they are not available. And I am running the longer front shocks on my rear because it is raised up in back,,,,,,,,
Re: Shocks for a 64
I found a listing for Gabriel shocks.
Front p/n 82062
Rear p/n 82003
If this helps.
Front p/n 82062
Rear p/n 82003
If this helps.
RipVanArkie- Moderator
- Number of posts : 987
Re: Shocks for a 64
Does anybody have the PN for air shocks front and rear? That is the direction I am heading after I re-arch my springs and do the kingpins.
Later,
Rip
Later,
Rip
Re: Shocks for a 64
Here some on eBay...
I would be suspicious of the diameter on these. They look like they might rub the frame if you using the stock upper mounts.
http://cgi.ebay.com/ebaymotors/Air-shocks-64-65-66-Chevrolet-GMC-G-Series-Van_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a15Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem110359728865QQitemZ110359728865QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Re: Shocks for a 64
The seller doesn't include a p/n either so you can research them. When I checked out Gabriel's website for the shocks in my previous post, they didn't give a listing for air shocks.
Re: Shocks for a 64
I've been looking at those ones on ebay for a while. I'm gonna check out the gabriels Nate posted, but either way, I gotta make some money first. Thanks for your guy's help,
Ryan
Ryan
Re: Shocks for a 64
Kakster- Number of posts : 236
Re: Shocks for a 64
I got some for my 67 at RockAuto.com, I checked and they has several for the 64 G10.
Re: Shocks for a 64
Yep, me too. Got these on the front. And gabriel highjacker airshocks on the back.
- Post n°19
Re: Shocks for a 64
- Post n°21
Re: Shocks for a 64
Ryan,
I think I paid about $60 for the shocks and had to buy the air tubing kit individually and if I remember it was $14.95.
I found the shocks on eBay and Googled for the tubing kit.
Dan
Dan
- Post n°23
Re: Shocks for a 64
Yes Nate close. But not as close as the pic makes it look. Got about 1/4" between the shock and frame. These vans normally would never need air shocks but I put my Motorcycle in the back and tow a 22' bass boat at the same time. Even without the air shocks it sits just fine but doesn't handle bumps well at all with the extra weight. These Gabriel Highjacker's have a PSI range of 25-200psi and I only have about 60psi in them to stabilize the load. It makes all the difference....
- Post n°24
Re: Shocks for a 64
The cheapest shocks i've found are at autozone, so i'm probably gonna go with them.
- Post n°25
Re: Shocks for a 64
Ryan,
If these are the ones your looking at. you'll need to buy the hose and tube kit separately.
Shock:
http://www.autozone.com/R,164064/vehicleId,1803601/initialAction,partProductDetail/store,941/partType,00661/shopping/partProductDetail.htm
(Keep in mind the price is for one shock only)
Tube and valve kit:
http://www.autozone.com/selectedZip,30281/initialAction,accessoryProductDetail/initialR,812967/shopping/selectZip.htm
These are the ones I have and you will have to put 4 large washers between the frame and shock. Also you have to buy longer Grade #8 shock bolts.
Not sure you reason for wanting airshocks, mine is for hauling. When not towing I drain the air to the min. of 25 psi otherwise it rides like a shackled-up pickup truck with an empty bed.
You might want to try this kit. Not sure on the spec's but looks like a smaller dia. shock so may be a better fit. Also even with shipping is almost half the price of the highjackers at Autozone.
http://cgi.ebay.com/ebaymotors/Air-shocks-64-65-66-Chevrolet-GMC-G-Series-Van_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a15Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem110362783925QQitemZ110362783925QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
But can't say anything about this kit since I've never used it.
Hope this helps.
Shock:
Tube and valve kit:
Hope this helps.
