Good evening everyone. I'll start this out by thanking you for taking the time to even look at what I was posting. I have a 1962 Falcon/Clubwagon I was wondering if anyone knew where to find replacement bushings, like the ones pictured, that holds the fuel line between the fuel pump and the gas tank. These sit in the larger holes in the frame. I just took my fuel line off to clean it and they fell apart. Any help would be great. Thank you once again. - Joe
Fuel line bushings
T1Joe- Number of posts : 23
Registration date : 2013-11-18
Fuel line bushings
fmc56- Number of posts : 553
Re: Fuel line bushings
Joe,
I found some hole plug/grommets that were the same diameter and used a hole punch to add the holes for the fuel and brake lines. I got them from a shop that installed aftermarket accessories, air conditioning, cruise control etc.
Fred
Fred
Thank you so much Fred, that sounds like a good place to try. Much appreciated my friend. - joe
