Here's the question.. When was the shift cable changed to 1 external cable system ??
+8
BoneMan
ThomastheTankVan
scottie8door
pittsdriver
rustytoolss
12 posters
Automatic shifter cable question
I've got a question about the shifter cable (automatic). My short tail transmission has External shift linkage.. But my service manual shows internal shift cables 2 of them .
Re: Automatic shifter cable question
So did all the A100s automatics use the internal shifter cables ?
- Number of posts : 8731
The early years used 2 cables, newer ones used 1, mine being a 69 only has 1 my guess somewhere around 66 was the change. Scottie 8 door could answer that.
I found a motor home in a junk yard in Cincinnati today with the auto shifter in it. Also found a rough wrecked A100 pickup 6cyl/3spd.
Tim the motor home should have had a steering assist or power steering from the factory.
those allways have some value
I didn't pay attention but the 413 engine and 727 trans are for sale. He said it's low miles and runs but has already been removed
jkr- Number of posts : 1148
the 2 cable systems were primarily in cars. i think it would be rare to see a 2 cable shifter in an a-series. one cable is for park only and the second does the shift pattern. and by no means am i saying they never came configured that way as mother chrysler was hard to figure out at the best of time. of all the ones i have owned and seen i never came across a 2 cable shifter in one. even the sweptline series trucks had 1 cable shifters i believe. i certainly would like to see both ends of the 2 cable setup in a van. seen a bunch in cars already....
pittsdriver- Number of posts : 335
Registration date : 2010-08-12
I believe the two cable was in the 64 only.
scottie8door- Number of posts : 39
Registration date : 2013-11-15
65 was the last year for the 2 cable auto, but maybe
a few leftovers were used in early 66's
scottie
scottie
scottie8door wrote:65 was the last year for the 2 cable auto, but maybe
scottie
See, answers like this from the master himself are worth the price of free admission alone! Scottie,whats the deal with the 3 different dash mounts if theres only 2 different shifters. I remember someone(Ter or John, aka RodStRace?) posted the 3 a long time ago but I forget.
the 64's used a different 2 cable shifter than
65's and early 66's. resulting in 2 different mounts
in the dash. 65 was the last year the trans were
built with internal cables.
sometime around 67 dodge came along with the
dash pad (wing) to keep your head from hitting
the metal dash, and moved the shifter hole closer
to the dash panel to allow a mount for the wing.
along with this they moved the key, wiper, headlite
switches inward to avoid your knees hitting them
in a crash. hope this helps.
scottie
scottie
Ah ,the wealth continues to overflow, thx Scottie.
ThomastheTankVan- Number of posts : 25
Registration date : 2014-03-13
My 65 has the 2 cable setup, but the park cable is broken. It doesnt hold the tranny in park. So I have to park on level ground and pull the E Brake. Once I came out of the store and couldn't find my Van! It rolled across the lot til it hit a curb. Thank god it didn't hit anyone or hop the curb!
Anyone know where to find a replacement cable or where to go to get it fixed? And an approximate cost?
BoneMan- Number of posts : 169
Registration date : 2011-06-23
ThomastheTankVan wrote:My 65 has the 2 cable setup, but the park cable is broken. It doesnt hold the tranny in park. So I have to park on level ground and pull the E Brake. Once I came out of the store and couldn't find my Van! It rolled across the lot til it hit a curb. Thank god it didn't hit anyone or hop the curb!
Hi, first I qualify - I have no experience with the 2 cable tranny, but I did a search and found this interesting enough to pass along.
http://www.ornocar.com/new_mopar_transmission_cables1.html
hope you can find some one to make one, this place has top of the line cables but expensie. the park cable is $279.00
Thanks. I hoping a local shop can just make one for cheap. I've had motorcycle cable made for my bike pretty cheap. hope these are too.
marty mopar- Number of posts : 79
Registration date : 2013-05-21
2830451 shift cable 110 inches long /threaded end have 3 NOS 195.00 each plus shipping
www.arizonaparts.com 1964-68 Van may fit later years????
THREADED PART IS 7/8 INCHES LONG
LOOPED END IS 1.25 INCHES LONG
Walker- Number of posts : 144
Registration date : 2010-03-13
eBay has 1 for 145. I got mine for 38 off of eBay, same part number was used on some motor homes.
- Post n°19
OK =Guys!!!!!!!!!!!!!!! There are 2 manufactures for these cables- all used by marine applications & can be had @ any boat repair place & marine wholesalers!! The black one is a "Morse" brand & there is a "red" one made by teleflex! I personally prefer the teleflex brand-also you can get these in a steel inside cable or a "stainless' which i prefer the last. Teleflex was always easier to use & move also -for me - almost 40 years using this stuff!! Boat yards & salvage places will have yet best to get from your small marine repair guy!!Cheaper 4 ya . u can get them in 1 foot increments .
supernaut- Number of posts : 73
Registration date : 2012-10-15
- Post n°20
i have one for sale. pm me if you want it
