I have a 1964 Dodge Dart that originally had a pushbutton shifter, I know that the best year of transmission to look for in passenger cars is the 1965 only because it is still shifted with the two seperate cables yet has the slip-yoke output shaft. Is the same true of A-100 truck/van transmissions? Are 64 and 65 shifted by two cables, one for drive gears and one for park? I'm going to the junkyard to look for a possible transmission to swap into my Dart so I can use the pushbuttons again, I had to delete them because they weren't compatible with the later model trans I already have in it. Also how do I look at the A-100 vin and tell what year it is?
thanks!
-Tim
thanks!
-Tim
