+57
SteelyVan
Bear
AzDon
mattimuss
whalemstr
LiveWire64
richie61
ditdater
Rick's 66 Chevy Van
Marcosis
Tice84
vern01
66_Barracuda
deepott71
kookykrispy
Vantastic
drc
kaz
64chevy
NipRing
scarlin
JAX
66mnecotruck
SDEconoTruck
61 posters
Dons day,,,,,,,
- Post n°226
Re: Dons day,,,,,,,
- Post n°227
Re: Dons day,,,,,,,
- Post n°228
Re: Dons day,,,,,,,
Wow! Kenny's talented. Beautiful scenery and made the bus jump to life!!!
- Post n°229
Re: Dons day,,,,,,,
64chevy- Number of posts : 364
- Post n°230
Re: Dons day,,,,,,,
This was the best sign I saw while there....
And somehow I ended up with this stuff....
- Post n°231
Re: Dons day,,,,,,,
- Post n°232
Re: Dons day,,,,,,,
Nice looking van. Is that air conditioning under the dashboard or just heating vents?
- Post n°233
Re: Dons day,,,,,,,
That's a combination heater/AC unit,,,,,,,,,,replaces the stock heater......
- Post n°234
Re: Dons day,,,,,,,
- Post n°235
Re: Dons day,,,,,,,
Nice...I like it! Looks right at home in there.
samsvan- Number of posts : 672
- Post n°236
Re: Dons day,,,,,,,
Don, do you know what brand of A.C. unit your friends van has? The one I bought is about the size of a concrete block. I'm trying to figure out how to mount it and wondered if the evaporator on the unit needs fresh air from where I took the heater out or not.Thanks
- Post n°237
Re: Dons day,,,,,,,
Never mind, found all my answers on another thread.
- Post n°238
Re: Dons day,,,,,,,
- Post n°239
Re: Dons day,,,,,,,
Hey, here's a mystery for you all. Leftcoast65 bought a clutch and pressure plate kit that seems to be the one that fits every Chevy:
http://www.autozone.com/1/products/286367-clutch-set-duralast-nu5472-2.html
Trouble is, his van had a throwout bearing that was 1/2" shorter than the new one that came in the kit. He installed the new pressure plate but neither he nor Don could fit the taller throwout bearing in there. It was too tight. So they just used the old, shorter bearing. But now the clutch does not fully disengage when you put the clutch pedal to the floor! And we lengthened the clutch adjustment rod all the way to its longest, even put in a longer piece of threaded rod to see if that would help. Nope.
If anyone out there has ever seen this before, let us know! Not sure what to try next.
We looked up the number in the bell housing casting and found it was a very common bell housing:
http://www.4speedconversions.com/403.html
Engine is a straight six 230 and the tranny is a 3 speed manual with no 1st gear synchros.
Thanks.
Thanks.
- Post n°240
Re: Dons day,,,,,,,
...it just seems strange that whatever engine/bellhousing he has in his van had a short throwout bearing in it,,,,,,,,the new kit has the longer bearing in it which is what we normally use on our vans,,,,,,,it just seems to me the clutch kit is the wrong one for his engine,,,,,but we got to start digging for what went wrong,,,,,,,,,I guess the pressure plate could be defective,,,,,,it definitely is not releasing,,,,,,,,but that list above shows 2 clutch arm ball studs , a short and a long one,,,,,that could be the problem,,,,,,,,
http://www.4speedconversions.com/3729000-2.html
this could be for the short bearing, since it is 2" long and that the one above is 1 1/2" long,,,,,
http://www.4speedconversions.com/3790556-1.html
- Post n°241
Re: Dons day,,,,,,,
Likely its the pressure plate- due to the different plates that the fingers come out to engage the PP. Id take the old unit & new parts into the store-if local & ask?? Get into an older auto parts store with some older parts "MANUALS"!! Id expect its the wrong clutch setup?? Im curious as to what was specified-?? car or truck for that clutch??
Ok in looking = the 230 cube 6 engine =1968 can take any of 3--- brand & part # can be crossed to ur application/brand!! Excedy # 04072= 11 " disc- 1 & 1/8 dia input shaft with 10 teeth
next is sacks-# K187406 10 " disc !! whit same 1 & 1/8 & 10 T
Next is also a listing for a disc with a 10 & 3/8 dia.!! all else same.
Now if its a V8- Excedy# 09049 11"disc all else same . Therefore - there could be differences in every throwout bearing & pressure plate!! Later models also use different sized clutches-V8 & 6 cyl. stuff (250) goes to a 12" disc!!
so there are several application differences!! Take in the old one!! Get some OLD!! Guy -like me to look up this stuff!!
- Post n°242
Re: Dons day,,,,,,,
Thanks for the ideas, guys!
The clutch disc that came out was 10" (maybe slightly over 10").
Here's a video where a guy is switching to a big block engine. He does some measuring and calculating and ends up getting an adjustable clutch fork pivot ball so he can get the proper distance from the ball to the mating surface of the bellhousing.
https://www.youtube.com/watch?v=22TwNOpXcPA&t=266
I would like to do this measuring with Leftcoast's bellhousing and pressure plate. Of course that means pulling the tranny and everything back out...
Don, those two different lengths of clutch arm balls is very interesting. If you (or anyone else out there) have got any bellhousings sitting around, would you measure the length of the ball? And the distance from ball to bellhousing edge, as shown in this video?
- Post n°243
Re: Dons day,,,,,,,
Agreed. You need to use the correct throwout bearing that is designed for that pressure plate. The shorter throwout bearing does not push the diaphragm spring in enough, so the pressure plate it is not releasing from the friction disc. I'd say you have the wrong clutch kit for your application. Later today after work I can check the part number on my clutch kit I used for the '67 I built last year. Should be correct for all L6 - 3 speed chevy vans. You can compare my part number to what you bought and see if there is a discrepancy.
- Post n°244
Re: Dons day,,,,,,,
- Post n°245
Re: Dons day,,,,,,,
Any evidence of the new clutch disc being thicker than OEM ? Ran into something like this on my bros 59 dodge, . material they used for remanufactur was thicker .
- Post n°246
Re: Dons day,,,,,,,
K1874-06 thats the stock replacement 6 cylinder 10" clutch. Diaphragm type pressure plate. organic friction disc, nothing fancy, but it fits and it works well for stock applications. 10 spline input on the trans (all G vans 3 or 4 speed) Got it at Orielly's. Used it on the '67 I built last year. We also used it on my buddy's '67 6 cyl van. Worked perfectly in both vans. About $140 for the whole clutch kit.
Its always nice weather down where you guys are. Up here in WA state we are enjoying something unusual: having lots of sun up here, and loving it! Just we will have to wait till July for those 70 and 80 degree temps. High 50's-low 60's though.. real nice weekend!
- Post n°247
Re: Dons day,,,,,,,
This is the kit he bought,,,,,,(could be made in China),,,,,,,,and it fits over 600 Chevys,,,,,,,and thats the one that I see put in our vans,,,,,,,,,HOWEVER,,,,,,his van had a much smaller throw out bearing in it and the new one would not even fit the fork without hitting the fingers on the pressure plate,,,,,,so something is definitely different about his van,,,,,,he had the clutch replaced about 10 years ago and one of the bolts was broken off in his flywheel, so I brought him another flywheel to use,,,,,so even using the old smaller throw out bearing that at least fit on the fork, he says it wont shift into gear,,,,so there are a lot of possibilities of whats wrong, so he needs to at least pull the trans out and see what ball is in that bellhousing,,,,,,,but it could be anything,,,,,,,and that little throw out bearing surely is a mystery on why it HAS to be in that van.......
- Post n°248
Re: Dons day,,,,,,,
- Post n°249
Re: Dons day,,,,,,,
Great photos, Don! That site you linked to shows the 1.5" and 2" balls.
I peeked in through the torn boot on the clutch fork opening and put a straight edge against the backside of the fork. Then I measured the distance from there to the back face of the bellhousing. About 1".
Don, would you check the one in your photo to see if that's what you get? When the fork is attached to the ball, is it about 1" from the hex-head-end to the back of the fork? Looks like you and Leftcoast have got the shorter of the two, wouldn't you say?
It seems to me that a longer ball might allow his short throwout bearing to push in further. But I'd rather find a way to allow the taller bearing that came with the kit to fit. You said the fit was so tight on that taller throwout bearing that it would have taken a hammer to get it in there. Would changing the length of the ball help?
Now I'd like to compare your fork and his. That site shows pictures of a dozen different GM clutch forks (though none look cast like ours) and says this about them:
Collection of clutch forks
Some of these forks are interchangeable with
small differences, others are totally unique.
http://www.4speedconversions.com/gm-forks
This is also being discussed over in Between the Seats "G"
General Motors clutch forks can be specific to
engine, car line and model year. These parts can
have a huge influence on linkage geometry and
therefore on pedal effort. I have a collection of
used, original, and N.O.S. forks that I will try to
identify and compare to each other.
Last edited by VANagain on Sun Mar 08, 2015 11:23 pm; edited 1 time in total (Reason for editing : added link to other thread)
- Post n°250
Re: Dons day,,,,,,,
