+57
SteelyVan
Bear
AzDon
mattimuss
whalemstr
LiveWire64
richie61
ditdater
Rick's 66 Chevy Van
Marcosis
Tice84
vern01
66_Barracuda
deepott71
kookykrispy
Vantastic
drc
kaz
64chevy
NipRing
scarlin
JAX
66mnecotruck
SDEconoTruck
61 posters
Dons day,,,,,,,
- Post n°526
Re: Dons day,,,,,,,
- Post n°527
Re: Dons day,,,,,,,
- Post n°528
Re: Dons day,,,,,,,
Don, did you use a bending tool to get that shape without pinching the line? BTW, nice job!
- Post n°529
Re: Dons day,,,,,,,
I would've bent that a little more away from the exhaust manifold and all. But if it doesn't create any vapor lock symptoms I guess it's okay? Looks good though.
- Post n°530
Re: Dons day,,,,,,,
Its pretty high above the manifolds,,,,,it has not caused us any problems,,,,,and the fan blows right on it and we run electric fans to blow air up from the bellypan,,,,,
- Post n°531
Re: Dons day,,,,,,,
- Post n°532
Re: Dons day,,,,,,,
- Post n°533
Re: Dons day,,,,,,,
,,,and the Vanettes, Suzy and Jacke were there,,,,I gave them their next assignments,,,,Jackes van keeps cutting out , so I brought a QuadraJet to show her how to take off the top of the carb and check the float and bowl for dirt,,,,,and since Suzys left front tire is wearing uneven, I brought a spindle and hub to show her what Kingpin bushings are and how to change them,,,,,
- Post n°534
Re: Dons day,,,,,,,
I need a professor like Don out here on the East Coast... hope the girls buy him an in&out Burger every now and then! LOL!
- Post n°535
Re: Dons day,,,,,,,
I have been trying to cut down,,,,,,,now it costs them a Subway Tuna sandwich for me to pick up a tool,,,,,,,,
JackeFriend- Number of posts : 940
- Post n°536
Re: Dons day,,,,,,,
- Post n°537
Re: Dons day,,,,,,,
- Post n°538
Re: Dons day,,,,,,,
- Post n°539
Re: Dons day,,,,,,,
- Post n°540
Re: Dons day,,,,,,,
Nice! Much better use for that space than an ashtray.
- Post n°541
Re: Dons day,,,,,,,
- Post n°542
Re: Dons day,,,,,,,
Looks like lots of great parts on that one.
- Post n°543
Re: Dons day,,,,,,,
- Post n°544
Re: Dons day,,,,,,,
- Post n°545
Re: Dons day,,,,,,,
Did y'all find any good trinkets at the swap meet???
Who took the pic? Or did you have the timer set on your camera?
- Post n°546
Re: Dons day,,,,,,,
- Post n°547
Re: Dons day,,,,,,,
- Post n°548
Re: Dons day,,,,,,,
Nice professional job! How did you get the carriage bolts into the frame? Go in thru the open end while the bumper brackets were out? How did you keep them from spinning? Drill square holes?!
- Post n°549
Re: Dons day,,,,,,,
you can reach in the ends of the frame once you remove the bumper brackets and you have the fuel filler pipe hole as well as 2 others to sneak the front bolts in with bent needle nose pliers,,,,,,I took a square file and made those 7/16" bolt holes square for the carriage bolts to fit in.....
- Post n°550
Re: Dons day,,,,,,,
Looks like a nice setup, neat, tidy and solid! Don, do you have a soft spot for Dodges? And what's with the advertising logo in the bed of that toy? Did you stumble onto a Collector's item? Tune in tomorrow for the answers to those questions...same Bat time, same Bat station!
