FINALLY got my Eco running. Then I noticed some anti-freeze in the radiator lip on top. Thought that a seam had split but noticed that it seemed to be from the pressurized cap. The noticed that a piece of copper tubing going thru a hole in the filler neck was loose. It's looks like someone had drilled a hole & stuck the tube in it for a drain & sealed with metal putty:affraid: . What's the use of a pressurized cap if you have a hole in the neck? Don't I need the pressure for the radiator & thermostat to work? Should I seal the hole?
Thanx Much!
Bratbike
Thanx Much!
Bratbike
